Author Topic: Just pulled the trigger on an Ohlins for my Connie!  (Read 10071 times)
Re: Just pulled the trigger on an Ohlins for my Connie!
« Reply #40 on: July 27, 2012, 04:52:02 AM »
I expect a full writeup tomorrow so you better get to wrenching tonight!   ;D
That shock is SO pretty Jay!
Offline Fretka
« Reply #41 on: July 27, 2012, 10:38:13 AM »
The spring Dan chose for you is 120 kg. The bike is heavy but you are relatively light and I was curious what spring rate he would choose.
If anyone else ends up modifying or replacing their rear shock this will give them a good guess as to what spring they will need......Thanx much.
Funny thing about Ohlins.... if you have never ridden a bike with them, life is fine...... but once you do, you'll never go back!  Congrats again!
BTW.... you'll need to do quite a bit of tuning to these suspension bits to get the ride qualities that you prefer.
Now is a good time to start thinking about what kind of "ride" you want, ie; soft/compliant initial compression for small bumps but still controlled further into the travel, where and how fast you ride etc...
When you purchase Ohlins, you essentially purchase a huge range of adjustability (with the added benefit of longer tire life as well).
Time to make friends with someone who knows suspension setup!
« Reply #42 on: July 27, 2012, 03:06:41 PM »
True indeed F, and yes I have a great suspension guy, he's one of the best in the PNW!  :)
Thanks C!  :)
