Where did you find this 40-50 degree claim? On the water side generally the heat exchange is at most 15 degree between in and out of an engine.
None the less, in hot weather sitting at long red lights I can watch the needle climb and climb. If I let it, it will climb into the red, and coolant will begin to puke out the overflow. None of which should happen, if the system were adquate for the ambient conditions.
I have had my pipes ceramic coated -- don't think that helped nearly as much as advertised.To my mind, I shouldn't have to do anything to keep the gage away from the red -- other than normal maintainence and such, of course. My radiator is clear both inside and out, the fan blade is original and in good shape, the thermostat is proper and functional, and the fan switch operates as it should. None the less, in hot weather sitting at long red lights I can watch the needle climb and climb. If I let it, it will climb into the red, and coolant will begin to puke out the overflow. None of which should happen, if the system were adquate for the ambient conditions.In every other way, my 2K is a pick of the litter bike. Low vibrations, good power, responded wonderfully to the SiSF exhaust cam gear, etc. Oh, alcohol has caused plugged pilots about three times now, but that's my fault.
... and the fan switch operates as it should. None the less, in hot weather sitting at long red lights I can watch the needle climb and climb. If I let it, it will climb into the red, and coolant will begin to puke out the overflow.
You might want to think about replacing your radiator cap. It may not be able to hold the proper pressure.
