Author Topic: WTS- Signal Dynamics Headlight Modulator  (Read 1259 times)
Offline Lone-Rider
« on: July 08, 2012, 11:20:38 PM »
For pretty much any application, single high/low, individual high and low, 1 bulb, 2 bulbs, 4 bulbs. This is the "old" style that involves cutting and taping into wire harness.
Installation is pretty simple:
Cut low beam wire, use wire taps to connect the cut wire ends to two wires on the modulator.
Cut high beam wire, use wire taps to connect the cut wire ends to two wires on the modulator.
Mount the photocell.
Tap into horn wire (optional).
Connect ground wire from modulator to any ground point.
I used this for several years on my C10, never a problem and definitely improves visibility.
$25 shipped
Wayne
Offline snarf
Re: WTS- Signal Dynamics Headlight Modulator
« Reply #1 on: July 09, 2012, 09:01:04 AM »
How old is this unit?
2002 Conc
1986 Conc "The spirit of COG"
Offline Lone-Rider
« Reply #2 on: July 09, 2012, 11:44:52 AM »
I bought the C10 in 2002, probably put this in in 2003 or 2004. Still working strong til the day I pulled it in 2011.
Offline Stasch
« Reply #3 on: July 11, 2012, 03:21:02 PM »
If you still have this, I'll take it.
You have Paypal?
Curious, what's the purpose of optional horn lead tap?
Offline Lone-Rider
« Reply #4 on: July 11, 2012, 08:53:31 PM »
You have Paypal?
Still have it, PayPal is fine. The horn tap is an optional connection. You attach tot he horn lead and when you hit your horn it will force the modulator to flash 3-4 times whether it is on or not, even at night. Just a little visual attention getter to go along with the horn.
Check your PM for paypal info.
