Author Topic: C-10 engine swap  (Read 2117 times)
Offline RFH87_Connie
C-10 engine swap
« on: June 27, 2012, 07:51:02 AM »
I threw a rod last weekend and i'm picking up a good (already been checked out) replacement motor this weekend.
1.  Are there any particular things to watch out for?
2.  I remember something about a pin in the drive shaft that might be hard to get to (someone elaborate please).
3.  I also plan on replacing the shifter seal, and both sets of coolant log o-rings and thermo.  Any other seals that I should be concerned about and easier to get to now?
4.  Do you put it in with or without the valve cover for clearance?
5.  Any other clearance issues or a better way to do something vs. the OEM and Haynes manuals?
6.  Leave the upper fairing on?
7.  Does the swing arm need to be unbolted or removed?
8.  Whats a realistic amount of hours i'm looking at to do the swap?  I'm pretty handy in the shop and have all the tools.
Ironically, I just did the carbs 2 weeks ago.  I'm going to start the tear down tonight.
Offline qman
    • Autobahn Motors
Re: C-10 engine swap
« Reply #1 on: June 27, 2012, 01:48:04 PM »
2. when you pull the boot back and turn the shaft you will see a small hole, use a small drift or something to push the pin in SLIGHTLY as you pull the drive shaft out
3. you may want to replace the blance shaft seal at the same time
6. leave the upper on
7. yes, unless you want to take the cylinder head off, I did mine a few years ago and left the rear end alone, since I was taking it apart anyway it saved some labour but it's a fussy fit. Patience is the key word. you may want to take the alternator and the starter off to remove some weight. Adjust the valves before you put it in.
That's about all I can remember, getting old and foggy!
Colin Prior has done quite a few, perhaps you can email him
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #2 on: June 27, 2012, 03:10:30 PM »
easy install - pull the output gear housing from the bevel drive (4 bolts); jack the engine up to line up the upper engine mounts on the head. When aligned, stick a round shank phillips screwdriver through both head mounts. Now jack the engine up at the back; it will rotate on the screwdrivers and come right into position to put the rear engine bolts in. Then install the front engine mounts and the bevel drive output housing. Engine is now mounted! HTH, Steve
« Reply #3 on: June 29, 2012, 05:32:25 AM »
Do I need a new gasket here?  Any particular version or brand?
I'm assuming that the engine is kind of pointing upward for this procedure, kind of like slipping my motor and trans back into the mustang in one unit?
Do I pull it out in the same manor?  Is this doable by myself or must I have an assistant for this process?
