Author Topic: Where to buy Grip Puppies?  (Read 17656 times)
Offline AlanS
Re: Where to buy Grip Puppies?
« Reply #40 on: December 27, 2014, 09:10:41 AM »
And thank you for the rubbing alcohol tip. If they don't move, it's less messy than with extra-hold hair spray (liquid, not aerosol).
Never had them move or twist, the only way to get them off that I know of is to split them open. But with rubbing alcohol there is no sticky residue on the OEM grip..
I've been using these for a while now... much better than Grip Puppies... easy on/off too!
http://www.shop.originalbeemerbuddies.com/SMARTSKIN-Original-Grip-Buddies-OGB-AB-SS.htm
I have seen the beemer buddies before, my problem is where to put the seam that is will not bother me.
The foam ones are uniform all the way around, a little cushioning too. Never have had them get slippery in the rain, closed cell so will not absorb water.
I like my grips a little fatter than OEM anyway.
Don't Panic!
'08 Suzuki DR650SE Mootzimo
'09 Honda GL1800Navi/XM HAFACAR
'12 Kawasaki ZG1400 Concours
