Author Topic: bearing designation question  (Read 1282 times)
Offline gpzrocker
« on: June 23, 2012, 05:33:42 AM »
For the swingarm bearings, my research has shown me the following:
on the bearing race itself: 32004J.
Most motorcycle parts stores show 32004JR.
Bearing designation references and the Concours part cross reference only show 32004.
I have found tons of 32004X bearings for relatively cheap ($5 to $6) and rarely the 32004JR at nearly $20. Each.
So does anyone know the difference, or can lead me to a place that can tell me? I am feeling from what I have read that the X or JR does not have anything to do with the bearing itself but want to be sure.
Frugally yours: Louie
Offline redzgrider
Re: bearing designation question
« Reply #1 on: June 23, 2012, 07:17:47 PM »
Well I found an NTN reference -- which sounds like a good start, since NTN seems to be one of the bigger OEM suppliers for Japenese bikes:
http://www.ahrinternational.com/NTN_nomenclature.shtml
according to this, J would mean a pressed steel cage and JR a riveted cage. I can not imagine how the cage is assembled making any difference.
Offline gpzrocker
« Reply #2 on: June 24, 2012, 04:37:42 AM »
Thank you redzgrider, I looked around and could not find anything.
Interesting, the X indicates a "cage design change".  I'm gonna give it a whirl.
Again thanks.
Offline gpzrocker
« Reply #3 on: June 25, 2012, 08:08:39 PM »
Found the difference: any tech heads around ?
Factory swingarm bearings:
32004j:  Dynamic load rating Cr: 27,300 N Static load rating Cor: 31,500 N
Cheap ones:
32004x: Basic dynamic load rating, radial  24000 N . Basic static load rating, radial 28500 N.
