Author Topic: I Hydrolocked my connie  (Read 12063 times)
Offline Jet86
  • California
« on: May 12, 2011, 03:41:46 AM »
Well it happened, how unlucky can i be, i hydrolocked my bike and the forum went down the same day, i guess i had a little luck on my side as no major damage was done.
i was 20 miles from home and before i left i switched the petcock to prime and drove off, every so often i will ride on reserve or prime for 20 miles or so then switch back to on when i get to where I'm going, well i forgot to switch it back this time.
came out of the supper market and hit the start button and it turned over a few times then  "CLICK" & Lock, it wasn't really loud but i knew immediately what it was and let off the switch quick, good thing i carry a small toolbox in the bag with basic tools, i just needed some shade, pushed the fat cow 2 blocks and found some, a 99 cent store was close by so i went and bought a towel to cover the Cylinder, pulled tank & plugs - unplugged the stick coils and moved the wires back so i wouldn't blow myself sky-hi, laid the towel over the plug holes and hit the starter button and she immediately turned over blowing out what seemed to be a pint of gas from the #1 Cylinder, and yeah even with that towel she spit in my face after partially blowing off the towel but i was happy she turned over, i cranked about 10sec then removed the towel and cranked another 10sec, let her rest 15min then gave 1 more good 15-20 second crank til i could not see anymore gas coming out, stuck her back together and drained the carb bowls and primed for 3sec then switched to on and she fired up, drove home and she ran just like always. i bet i wont ride with it on prime anymore.
the petcock is working like it should 6 months new from murph's.
TWO QUESTIONS
1. Can the bike hydrolock if I'm riding it?
2. Do i now have gas in my oil? i only rode home 20 miles and haven't started her since.
Offline Electroken
Re: I Hydrolocked my connie
« Reply #1 on: May 12, 2011, 03:47:51 AM »
I'm glad you got off easy.
1. It will not hydrolock while running unless you ride into a lake.
2. If it sat for more than a few minutes with fuel in a cylinder, you have fuel in your oil.
Offline Jet86
  • California
« Reply #2 on: May 12, 2011, 04:37:20 AM »
Thanks i better change the oil then, i was in the store for at least 15min or more.
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #3 on: May 12, 2011, 05:36:39 AM »
 you'll need to address why it hydro'ed, or it'll do it again. I'd suggest to get the petcock replaced, tank cleaned, carbs cleaned, and get some overflow tubes installed - just in case. with hydrolock and the connie, it's not an issue of "if" it's an issue of "when" - and the results range from contaminated oil to a bent connecting rod - HTH, Steve
Offline Jet86
  • California
« Reply #4 on: May 12, 2011, 06:06:52 AM »
The petcock is about 6 months new from murph's and working fine, thats the first thing i checked when i pulled the tank, it's a Tank + carb issue = stuck float/needle, I wont have any money for at least 2 months' so after the oil change she will sit for awhile.
btw would you happen to have a clean used tank for sale? i think i read you said you had one for sale but not sure if you sold it or not.
Offline mlf73
« Reply #5 on: May 12, 2011, 06:36:19 AM »
The petcock is fine right...since it was on prime...it did what it was supposed to do?  The failure was with a carb needle or float and of course, no overflow tubes?
« Reply #6 on: May 12, 2011, 07:04:24 AM »
  Nice catch! He did say that in the OP, I just missed it  :-[ .
   I'd like to add that it has been said that hydrolocks are the result of 2 failures, the petcock and a float needle. I'm modifying my position on that, after having done literally dozens and dozens of carbs at this point. I think that the floats apply such light seat pressure to the needles that the head pressure from a reasonably full tank of fuel could overcome a needle with a soft spring and cause it to seep, resulting in hydrolock. HTH, Steve
  bTW, I do have a very nice tank - email or PM if interested - steve
« Last Edit: May 12, 2011, 07:06:15 AM by Steve in Sunny Fla »
Offline Jet86
  • California
« Reply #7 on: May 12, 2011, 07:49:46 AM »
And i keep my tank full most of the time, and it was my fault for leaving it on prime when i new full well the carbs has been needing attention for a long time now, i think they needed rebuilt since the day i bought it 3 years ago but it has only been the this last 3 months they getting really bad, once the bike is good and warm and i shut it off for 15min then try to start it it backfires out the exhaust, and while im cranking i can hear whats seems to be a slight knocking in the head, i think that knocking is mini hydrolocks.
PM on it's way
Offline dbethel
« Reply #8 on: May 12, 2011, 09:49:20 AM »
You were lucky, but check piston height to make sure.
D.
Offline norcalbarney
  • I got me an '86
    • Bikes, bro
« Reply #9 on: May 12, 2011, 09:55:08 AM »
I did the same thing.  I left the petcock on prime after pulling the tank, and my float valve failed in #4.  There was gas under the carbs, but I was foolish enough to keep trying to start it, tho.  I had a HUGE backfire, and now the #4 piston is about 3/8 lower than #1, and it won't crank past that point, so I've got a bent rod.  Now it's my parts bike!
I have sent a set of carb bowls to Steve in S Florida for the overflow tube treatment.  I think it's $70 well spent, especially for newbies like me.  Or you could install them yourself.  There *used to be* a post around here.... : )
« Last Edit: May 12, 2011, 10:28:25 AM by norcalbarney »
Offline mdr
« Reply #10 on: May 12, 2011, 11:01:12 AM »
Lets run the numbers...
I'm not near a bike, but I'll guess around 12" from top of the tank to the float needle.  I'll show the formulas so you can calc it yourself within 0.1mm if you want :)
pressure head = (specific weight) * height
specific weight ~= 0.026 lb/in^3 (wikipedia and others)
pressure head = 0.026lb/in^3 * 12in = 0.312 lb/in^2 or ~0.3PSI
In a thread on the old boards it was said the seat is about 2mm in diameter, 1mm or 0.04" radius (about 39.4 mils).  So,
area = pi * (radius)^2 = 3.14 * (0.04)^2 = 0.005 sq in
force = pressure * area = 0.3 * 0.005 = 0.0015lbs or 0.02 ounces.
Unless I've goofed the math, I don't think so.
Mark in Austin
'01 Concours, Vrooomm
My "Tech Page"
  • I got me an '86
    • Bikes, bro
« Reply #11 on: May 12, 2011, 11:32:37 AM »
I'd like to add two more reasons that Connies seem to hydrolock, that Steve may have overlooked with his years of experience : First is riders leaving the petcock on Prime, bypassing the vacuum on the petcock, allowing fuel to press on the needle valves.  Sure, everyone should keep the petcock on ON, not prime, but some riders (like me) might not know that.
A second, worse, less forgivable mistake ignorant riders (like me!) make is to try to start the bike after the needle valves failed, and there's already gas in the cylinder.  They see the pool of gas, and try to start it anyway.  It's hard to believe that pressing that little red button on my sturdy bike could kill it, but it can.  In my case, there was a huge backfire, and the bike was hydrolocked.  Now I've got a carcus.
Certainly Steve knows his Sh*t, and you should listen to him.  I'm just adding this for people that don't know nuthin, like me.  And get Steve's overflow tubes installed!  : )
Offline Roadhound
« Reply #12 on: May 12, 2011, 02:40:09 PM »
Just always remember, when you approach your bike, if you see gas on the ground or if you smell gas, check it out before you hit the starter button. You and your Concours can live a long and happy life with or without overflow tubes as long as you use your head.
Don Ricks
Atlanta, Ga.
Offline Daytona_Mike
« Reply #13 on: May 12, 2011, 03:52:24 PM »
That will work only if you smell gas. Many times you may not. It only takes a few seconds of leaving a manual petcock in the ON position or an automatic on Prime (or it failed in Prime) to have a Hydo-lock Occur. I never smelled gas when I almost hydro locked and I was in a garage. I even had a sign that said to tap the starter to make sure the engine is free but I kept forgetting to do that.
You may take your chances and possibly   live a long happy life without over flow tubes but you will not be safe from Hydrolock at all and  thinking you  do not need over flow tubes is a mistake that could cost you your engine. Why take the chance? Get overflow tubes installed ASAP.
Offline Roadhound
« Reply #14 on: May 12, 2011, 07:01:28 PM »
Well it's worked for me for over 500,000 miles. If I turn my petcock to prime my hand never leaves the petcock until I turn it back to on or reserve. Leaving the petcock on prime is the most dangerous thing you can do, and totally avoidable.
Don Ricks
Atlanta, Ga.
Offline Jet86
  • California
« Reply #15 on: May 13, 2011, 12:37:56 AM »
It was a windy day, i didn't smell or see anything til after the fact, then i did see a small amount of gas coming from the air box but i still didn't smell it cause the gusty winds, Before i leave the house i walk around the bike looking for this sorta thing among others, every so often i move the petcock around and ride for a few miles to keep it working properly and from drying out, seen that tip from this forum or should i say the old forum, any way you put it it was still my fault for not hydro proofing the bowls or at least rebuilding the carbs but i cant do it where i live and money is hard to come by so i will just have to save up.
  • I got me an '86
    • Bikes, bro
« Reply #16 on: May 13, 2011, 12:56:18 AM »
Wait, haven't we proved the the petcock being on prime *and* a leaky float valve was the cause?  Is it ok to run a leaky float valve for a while if the vacuum on the petcock is ok?  Can't Jet86 simply change the oil and ride now? :o
I'm not implying that rebuilding the carbs is a bad thing, just wondering it's absolutely nesessary before riding it again.  I'm a cheap bastard, and I'd rather ride than work on 'em, too.
I found a single carb rebuild kit on eBay for $27.  That's about a tank of gas in CA, so if you can't afford that, you can't afford to ride anyway!  ;D Ok, Ok, rebuilding all four carbs would be $108, and it'd be silly to pull the carbs and only rebuild one.
Offline SteveJ.
« Reply #17 on: May 13, 2011, 04:56:13 AM »
You can do this work yourself. Read up on MOB's carbbie article and do not take short cuts. Do install overflow tubes. Do NOT us K/L carb kits, there are issues with them, something like a float or float clip issue, and the needles are suspect, IIRC. Plus, it's K/L. (I'm assuming the ebay kits are K/L)
The issue that comes up is iff'n you're not a carb magician, identifying what's normal or what's not. Again, refer to MOB's write up. See if you're up for it.
Good Luck, signed, a happy customer.
Disclaimer: I know SiSF.
America's Seaplane City
  • I got me an '86
    • Bikes, bro
« Reply #18 on: May 13, 2011, 09:20:08 AM »
Disclaimer: I read a lot, understand about half, and strip bolts every time I work on my bike... :). It's prolly best that I let others answer on hydrolock articles.
I was however able to dig up some articles in Google's cache of the old forums.  Maybe this link can help locate the Man of Blues article?  When you find the correct article in google, you'll need to click on "Cached" to see the actual article.
http://www.google.com/search?hl=en&q=Site:concours.org++site:forum.concours.org+man+of+blues+carbs
Hope this helps.
Offline Jet86
  • California
« Reply #19 on: May 13, 2011, 12:23:45 PM »
If i had a garage or even a back yard i would have already fixed this issue long ago, i cant do this kind of work in my apartment and cant do it outside either, manager lives on site, i'm pretty sure i can keep on riding after i change the oil, after all i rode it home 20 miles after the lockup and it ran fine no power loss or anything, just don't put it on prime anymore and i should be ok "unless the petcock fails" my best bet is to get a clean tank or seal the one i have then send the carbies off to SiSF. i actully would feel better sending them to Steve then doing it myself, as i said though money is tight and will have to save a bit.
