Author Topic: I probably ruined my engine today!  (Read 9021 times)
Offline saddletramp
« on: May 22, 2011, 10:02:14 PM »
I decided to change the oil for the first time on my 2009 C-14 that I purchased used in February.  I've put 1,000 miles on the beast so I had to change the oil so I knew when the last change was done.  It had 11,074 miles as of today.
I purchased some Rotella 15-40 wt at Walmart & a Fram filter but when I got home I realized I had some Castrol motorcyle oil & some Rotella synthetic left over in some gallon jugs from my FJR days...so I poured them in first...then topped it off with the Rotella that i had just purchased.
I know, my engine will probably blow up.   Mixing oil... what was I thinking!  I guess you get what you deserve!  ;D
Offline katata1100
Re: I probably ruined my engine today!
« Reply #1 on: May 22, 2011, 10:08:26 PM »
Don't dig the fram filter, but I think she'll live.
I once had the gas in my katana 1100 contaminated with gas. I refilled it with 1 qt redline 10-40, 1 qt Mobil 1 5-30, 1 qt Mobil 5-40 delvac and topped it all off with what was left of the Rotella 5-40. I wasn't trying to be creative or experiment; that was all the oil in my garage and I didn't feel like going out getting some oil!
Offline Jaxter
« Reply #2 on: May 22, 2011, 10:09:56 PM »
Thanks for the warning...I didn't know mixing different types of oil could be explosive.
I've Never Had A Better Day
Offline firetruck41
  • No pictures means No Posting
« Reply #3 on: May 23, 2011, 05:33:27 AM »
No your engine is fine. you did nothing to affect reliability. they say don't mix synthetics but you can top off safely. so go have some beers. I've never seen or heard of a jap engine dying or loosing performance because of that.
2011 connie. silver
corbin seat on order
motorcycle larry lowers.murphys risers
Givi E55 mono-key. passenger peg lowers
Offline Afm252
« Reply #4 on: May 23, 2011, 06:36:23 AM »
I agree, no worries. I would be more worried about doing something stupid like inadvertantly hitting the kill switch upon arrival to the local grocery store, and then blaming yourself because you thought you killed the bike after the oil change you did because of the oil "leak" you found near the drain plug. Only then to realize after screaming and cussing in the HEB parking lot for an hour and after removing every hair folicle remaining on your head that it was the kill switch all along....not that it happened to me of course.  ;)
Mike T
09 C14 "Turtle"
07 CBR 600rr Blue/ Silver
98 CBR 600 F3 "Desert Storm"
Offline jjsC6
« Reply #5 on: May 23, 2011, 06:51:11 AM »
I don't really think the OP was being serious about ruining his engine. ;D ;D ;D
Jim
2010 Concours - Sold Feb 2013
Current bikes....
Offline manowarwi
    • Midwest Sport Riders
« Reply #6 on: May 23, 2011, 07:04:19 AM »
I always thought you had to flush your oil system out with 2 gallons of the new brand / weight whenever you wanted to change  ;D
Offline So Cal Joe
« Reply #7 on: May 23, 2011, 07:38:28 AM »
As long as you didn't add blinker fluid to the oil by mistake you should be O.K..
« Reply #8 on: May 23, 2011, 07:45:39 AM »
I am a big advocate of mixing oils, but using a Fram filter on a motorcycle is just plain dumb.
Bob
« Reply #9 on: May 23, 2011, 07:48:46 AM »
Oil thread!!!!!   :popcorn:
Offline JetJock
« Reply #10 on: May 23, 2011, 09:33:20 AM »
Double up on the popcorn. It's oil AND FILTER thread and the Fram-slams have already begun.
Offline Tremainiac
« Reply #11 on: May 23, 2011, 09:42:55 AM »
Make sure it's good and clean by hosing out thoroughly. The hose screws right into that plug thing.
Leave the filter out, because the paper in it will get soggy.
Especially the Fram filters.
Particularly absorbent compared to other brands.  ::)
Offline gflint
« Reply #12 on: May 23, 2011, 09:57:54 AM »
Before you hose it out be sure to run the engine with the drain plug out.  You want to get rid of the old oil in the oil pump and the oil gallerys.  If you rev it up hard it will also clean out the oil in the cam area.  It is also sometimes nice to flush the engine with ether to get that nice shiny all over the inside look.  You can check how shiny the insides are by holding a match over the oil filler hole.
Offline Guinness
« Reply #13 on: May 23, 2011, 02:08:04 PM »
Personally I like the Harley way: Chrome everything.  That "shiny look" for your engine innards is best done with a couple quarts of Rustoleum Metallic Chrome paint.  Pour it in the filler hole, start the engine, rev hard (to distribute the paint evenly), and you'll have a nicely chromed engine (from the inside).
Suggest that to 10 Harley riders and I'll bet 5 of them will do it.
Yup, I integrated Harley bashing in an oil thread.  What's next?   :o
2010 Concours ABS
Offline Afm252
« Reply #14 on: May 23, 2011, 06:00:26 PM »
Personally I don't think KiPass would allow the engine to fail!
ADDED KiPass to the thread :D
Mike T
09 C14 "Turtle"
« Reply #15 on: May 23, 2011, 06:06:05 PM »
The paint is a good idea, you can never have enough chrome!
Mixing oils is the norm while running a car tire.  I even add a little kerosene to my 91 octane to give a little extra something.  And I scrape pegs in every corner and fly through every school zone with no negative effects.   ;D
Offline Arata
« Reply #16 on: May 23, 2011, 07:03:44 PM »
mix all of those oils in your lawn mower, not you Connie!
2014 V Strom 1000
2008 C14
2004 ZRX1200R
1993 GSXR 1100
« Reply #17 on: May 23, 2011, 07:25:43 PM »
Fram should make oil...........
 :popcorn:
Offline R Nelson
« Reply #18 on: May 23, 2011, 07:57:32 PM »
I tried mixing oils once and then had to do this.   ;)
My Current Rides:
2008 Kawasaki Concours
1999 Kawasaki Vulcan Classic 1500
2006 Ford F150 SCAB, 5.4L
« Reply #19 on: May 23, 2011, 07:59:07 PM »
Why did you take your toaster apart?   ;D
