Author Topic: Fairing stay?  (Read 1740 times)
Offline VodkaAndPickles
Fairing stay?
« on: May 22, 2012, 07:08:20 PM »
Is the main fairing stay for the 86-93 models the same as the later ones?  Both my antlers have cracked and I'm looking for a replacement on Ebay.
Re: Fairing stay?
« Reply #1 on: May 23, 2012, 06:24:42 PM »
Bump...
Offline cmoore
Re: Fairing stay?
« Reply #2 on: May 24, 2012, 04:01:14 AM »
Are you talking about where the main fairing attaches to the steering head?
2010 C14
Dallas, Texas
Offline shibby_cbs
Re: Fairing stay?
« Reply #3 on: May 24, 2012, 08:05:25 AM »
the upper fairing stay for the early models are different than the laters as the gauge cluster is different which i would imagine has different mounting points. im sure that isnt the only difference.
Offline AZBiker
    • My photos
Re: Fairing stay?
« Reply #4 on: May 25, 2012, 12:14:44 AM »
The 2 different stays aren't compatible.  If you run the newer stay, you can't run the older gauges.
rubber side down,
Derek
93 Cali black & red
Re: Fairing stay?
« Reply #5 on: May 25, 2012, 09:42:34 AM »
Thanks everyone, just ordered a '88 bracket off of Ebay.
Offline Stasch
Re: Fairing stay?
« Reply #6 on: May 26, 2012, 10:15:23 AM »
You can modify one the old generation to fit the new gauges, horn mounts and inners, provided you have the wrecked / bad stay from and old generation bike.  You'll need it to cut some mounting brackets off and weld onto the other.
For bolt and play - get the proper generation.  86-93 or 94-06.  Its much easier.
