Hi,
I'm attempting a valve adjustment for the first time (by me), following the Clymer manual and some other pages on line. When I pulled the plug wire on Cylinder 2, it was wet with oil. After removing the cylinder head cover, I couldn't find the rubber gasket for Cylinder 2 that sits under the head cover around the sparkplug well. That well has oil in it to the top of the plug.
If this gasket was not installed last time the cover was off, is it possible the engine would run smoothly with oil in there? I'm certain all 4 cylinders were working fine. I need to remove that oil with a turkey baster or something, right? Otherwise, it will drain into the cylinder when I change the plugs.
Any advice is most welcome. Thanks for your expertise.
