I've just replaced my rear shock with a Progressive 420 (which I'm very please with) and have done the stock fork spring cut and spacer modification. I now have a KB fork coming that I should have installed by the weekend. So the next logical thing to do is install emulators in the forks. As far as I can tell I there are only two options, RaceTech and Ricor. The Ricor apears to have the advantage of not having to drill out the holes in the damper rod, you just have to use the lower viscosity fluid. Prices I found are $170 for the RaceTech and $180 for the Ricor. I'd say the advantage goes to Ricor because of the simpler installation. So I'm looking for some input. Are these products pretty much the same thing? They look like it to me but I'd be glad to hear from people with some experience with either or both of them.
Thanks,
Todd
