Author Topic: backfiring on deceleration  (Read 6384 times)
Offline Daggett
« on: April 16, 2012, 09:07:23 AM »
I need your help fellows.  I just purchased my first Concours, a 2002 with 48k on it. The seller told me that he got it from a honda dealer who had drilled out the jets.  He says to 24mm, but I think that is the part no. because that seems quite large for a jet.  Anyhow, I have noticed when riding it that when I decelerate it makes a pft... pft.. pft... sound.  I cant tell if it is coming from the motor or the exhaust, although it sounds like it is coming from the exhaust.  I have also noticed that when idling on startup I can smell fuel sometimes and it is definitely running rich.
Any suggestions.  I have only had the bike for a week and I have put seafoam in a fresh tank of gas.  A mechanic told me to just run that through the carbs and make sure I decelerate a lot to force the fuel through the idle jets.
I dont understand how clogged carbs can make it run rich, but I am by no means a mechanic.
Any help or guidance would be appreciated.
I live in a northern suburb of Cincinnati so if anyone is local and can call me feel free.  305-6247...
Offline timsatx
Re: backfiring on deceleration
« Reply #1 on: April 16, 2012, 01:15:36 PM »
Who the freaking hell would drill out the jets when you can just buy some? If I was you I would buy some new jets properly sized and put them in and see what happens. Besides that, 24mm is almost an inch in diameter so that doesn't sound right in the first place.
Offline Daytona_Mike
« Reply #2 on: April 16, 2012, 05:11:40 PM »
Wow, that is a new one. You can also do an 'Italian Tune Up too'  Put it in neutral and hold the throttle wide open. that should clean any cob-webs out.
Just kidding please do not do that!!
Offline datsaxman@hotmail.com
« Reply #3 on: April 16, 2012, 05:59:12 PM »
Check the carbs to see if everything is connected, and that the little rubber caps that cover the fittings you use to synch the carbs are all there.  Mine did what you describe, and one of the caps was missing.  Better now.
saxman
161.5RWHP on the dyno
Formerly Silverdammit!
Offline Stasch
« Reply #4 on: April 16, 2012, 07:07:47 PM »
Also make sure the carb manifold and carb boots and carb boot clamps are properly in place and snugged up.  Vacuum leaks here can cause spitting and huffing like you describe.
Offline Daggett
« Reply #5 on: April 16, 2012, 08:17:29 PM »
I appreciate the input.  When I got home tonite I started the bike and it is now making the noise when idling.  Having a little time to look at it I figured out that it definitely is backfiring throught the carburetors, not the exhaust.  I'm hoping there is a stopper missing or maybe a loose carb boot or manifold.  Once again, thanks
Offline AZBiker
    • My photos
« Reply #6 on: April 19, 2012, 05:23:04 AM »
There are air passages in your carbs in addition to fuel passages.  Some of the air bleeds on my carbs were clogged.
The person that told you to "decelerate a lot" may be a lot of things, but a mechanic they ain't.
Protip:  Do not ever take anything you own to that person to be fixed.  The universe was being generous by dropping you a hint.
rubber side down,
Derek
93 Cali black & red
Offline VodkaAndPickles
« Reply #7 on: April 19, 2012, 07:13:56 AM »
Mine also backfires really loudly on decel, like a gunshot.  It comes from the right muffler.  Bad gasket maybe?
« Reply #8 on: April 19, 2012, 11:27:01 AM »
Stuck "air cut" valve on carb, or even sticky reed valve on valve cover....will cause this.
« Reply #9 on: April 19, 2012, 01:48:49 PM »
I have block-off plates, does this affect it?
Is the backfire harmful to the bike?
Offline snarf
« Reply #10 on: April 19, 2012, 02:24:05 PM »
 :popcorn:
I dont see how it would.  The reeds allow air not fuel to enter into the exhaust. If they were stuck open I would think you would actually be reducing the fuel to air ratio.  If there is to much fuel in the exhaust; it got there way before the reed valves. I may be way off on my thinking and I am always ready to be taken to school.
2002 Conc
1986 Conc "The spirit of COG"
Offline snarf
« Reply #11 on: April 19, 2012, 02:26:27 PM »
Can you please explain this to me one more time
2002 Conc
« Reply #12 on: April 19, 2012, 03:12:41 PM »
:popcorn:
What would cause too much fuel in the exhuast?
Offline snarf
« Reply #13 on: April 19, 2012, 03:22:32 PM »
The fuel/air ratio can only come from one place...the carb.  I am by know means an expert on carbs; hopefully SISF or MOB will explain a little more in-depth.
2002 Conc
« Reply #14 on: April 19, 2012, 03:28:59 PM »
It only happens in the right exhaust, so it's either carbs 3, 4, or both.  What would cause only one or two carbs to run rich and the other two to be fine?
Offline snarf
« Reply #15 on: April 19, 2012, 03:30:54 PM »
As MOB mentioned a stuck "air-cut" valve.  I sent SISF a pm.  Im sure he will be by shortly.
2002 Conc
« Reply #16 on: April 19, 2012, 03:33:45 PM »
So is this damaging the bike, or no big deal?
Offline snarf
« Reply #17 on: April 19, 2012, 04:35:27 PM »
I'm by no means an expert; a large enough back-fire 'could' damage the exhaust. While highly unlikely, it could still happen. Backfire is generally from to much unburt fuel in the exhaust gases. They enter the exhaust and detonate after the exhaust stroke. Are you getting good spark on all four cylinders? If one or two cylinders aren't burning all the fuel during the compression stroke this could be where your backfire is coming from. Like I said this is just speculation.
2002 Conc
« Reply #18 on: April 19, 2012, 04:38:40 PM »
Don't know about spark; I've been doing so much work to this bike lately that bad spark would just be one more thing wrong with it.  How would I go about testing it?  I replaced the spark plugs 10k miles ago or so.
Offline snarf
« Reply #19 on: April 19, 2012, 05:34:16 PM »
I know you have B-O plates, but do you have stick coils. New spark plugs does not mean good plug wires.
2002 Conc
