Author Topic: alternator  (Read 3696 times)
Offline Cavediver
alternator
« on: March 27, 2012, 05:43:26 PM »
I have a small problem. I just put fog lights on my C-10. It was 28 degrees this morning, so I plugged in the heated gear. When I slow down (you saw this coming didn't you) the volt meter starts to drop, and the heated gear isn't as warm. I know the ZZR1200 alternator fits. I haven't seen one for a while, does the ZRX 1200 altornator fit as well?
Jack
Offline T Cro ®
Re: alternator
« Reply #1 on: March 27, 2012, 07:13:20 PM »
Yes the ZRX alt will fit but it will do no better than the stocker as the output is the same....
Tony P. Crochet
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
Re: alternator
« Reply #2 on: March 27, 2012, 07:42:22 PM »
You can save a couple of amps for free by replacing the tail light, front turn signals and dash lights with LEDs and disconnecting the license plate light.
Offline T Cro ®
Re: alternator
« Reply #3 on: March 27, 2012, 08:11:41 PM »
That was one of the first things I got ride of.... Thing is big enough to be used on a full sized truck!
Tony P. Crochet
Offline kzz1king
Re: alternator
« Reply #4 on: March 28, 2012, 05:54:25 AM »
Are these LED replacement bulbs or do you need new sockets and all?
Wayne
2010 CONCOURS
1974 Z-1
  • Moderator
Offline Cavediver
Re: alternator
« Reply #6 on: March 28, 2012, 01:42:01 PM »
This is why this is such a great forum, great responces from great people. I'll wait for a ZZR to pop up.Thanks Guys.
Jack
Re: alternator
« Reply #7 on: March 29, 2012, 08:15:33 AM »
in the mean time, remove and clean all your battery cables, and retighten them (skipping this and saying they are fine without actually doing it is only lying to yourself...)
also check closely, the 2 blade inline connection coming from the generator up to the harness, over near  the battery box and main harness there....make SURE that isn't doing a Meltdown....happens more than you imagine, and when it does go south you are outta commision....till you re do them.
Offline Vic Salisbury
Re: alternator
« Reply #8 on: March 29, 2012, 09:53:32 AM »
Speaking of those connections,,,,,is there anyway to clean the bladed portion of the (any) connector? Maybe even get it bright and shiny  ;D  Some magic chemical?
I'm also thinking of, like the bladed connectors on the J-box, how to clean a really tarnished one.
Vic Salisbury
COG #3673
'97 Concours "Grinch"
Sarasota, FL
Offline txfatboy
Re: alternator
« Reply #9 on: March 31, 2012, 09:52:24 PM »
Vic, my Mac tools dealer showed me a new terminal cleaning kit. It looks like mini blades.... female and male that have a "grit" bonded to them. They are designed to clean several types/sizes of male/female connectors. I haven't purchased them YET so I don't have a review to give. I have also used chemical cleaners as well in the past. I'm sorry but I can't remember the brand/name of said cleaners. I do remember they were a terminal contact cleaner, they were fairly expensive, and did a VERY good job. The greatest advantage to using the chemical cleaner was that it didn't remove any of the base metal of the terminal, only the corrosion. HTH
Woody
2014 V-Max
1991 Connie, 17 inch wheels,  ZRX1200 forks with racetech valves and brakes, zx9/ zzr1200 hybrid rear shock, 2 min mod and exhaust cam sprocket from SISF, tubular handle bars, hywy pegs, HID headlight and LED running lights.
Offline goatmar
  • Go where God wants you.
Re: alternator
« Reply #10 on: April 13, 2012, 02:49:45 PM »
Oh thanks George, now I'm going to have to tear my dash apart AGAIN so I can put in those LED's you listed.  Well I'll have extra dash bulbs for someone who needs them.
Dave Muzzey
COG#7957
'01 Connie "BLUE"
Re: alternator
« Reply #11 on: April 13, 2012, 08:36:10 PM »
cool, thanks, I'll check out the Mac tools. I also found a local "old school" electric parts house, see if they have the chemical cleaner recomendation. I like the thought of not taking away base metal
Vic Salisbury
COG #3673
Sarasota, FL
Offline txfatboy
Re: alternator
« Reply #12 on: April 13, 2012, 09:18:06 PM »
Vic, I was doing a little surfing and found a website that has some chemical cleaning products that look promising and aren't too pricey. It is Craig labritories inc. and the product is Deoxit. They even have a "travel/survival" kit that comes in a small hard plastic case for $25.00.
Woody
2014 V-Max
Offline jklhill
Re: alternator
« Reply #13 on: April 17, 2012, 02:21:48 PM »
Converting your headlight over to HID will save a bunch of power also.
