Author Topic: Riser question from new owner  (Read 9599 times)
Breaker19
Re: Riser question from new owner
« Reply #20 on: March 27, 2012, 06:53:30 PM »
So she's not your wife or girlfriend??  ???
I was trying to be polite before, but if you're not with her then now we can comment even more huh??  ;)
Welcome to the forum bro!  :chugbeer:
Haha, nope, none of the above. Heck, she's like my daughter's age, I thought it'd be a neat pic to modify for an Avatar, that's all.
Offline Jack Daniels
  • Ain't nobody chasin' me boy
« Reply #21 on: March 27, 2012, 07:16:55 PM »
You and me both! A buddy of mine had the actual movie poster in his room at his house many years ago, he conned it off the theater owner or staff somehow... I'll have to email him and see if he still has it! :)
Just looked, there are some repros and originals on ebay.  :)
Breaker19
« Reply #22 on: March 27, 2012, 07:19:31 PM »
Cool, get yourself one! ;)
Offline koval68
« Reply #23 on: March 27, 2012, 07:20:15 PM »
Yeah, right...! I've heard that one before..... ;)
- Mahatma Gandhi
« Reply #24 on: March 27, 2012, 07:20:58 PM »
I think I will but I'm running out of room in my basement bar!
Breaker19
« Reply #25 on: March 27, 2012, 07:24:35 PM »
What's a basement? (Florida here).... lol
Offline SANDPSYCHO
« Reply #26 on: March 27, 2012, 09:05:42 PM »
From what I have heard it is a room under a house that guys that can't ride their motorcycles hang out in while they wait for the snow to melt. I'm from SoCal where we keep that white stuff up in the mountains where it belongs. ;D
« Reply #27 on: March 27, 2012, 09:16:24 PM »
Well if that's the case then I'll fix it for ya bro!  ;D ;D ;D
Breaker19
« Reply #28 on: March 28, 2012, 03:47:07 AM »
Z, here's another one for ya... ;)
Breaker19
« Reply #29 on: March 28, 2012, 04:13:24 AM »
Nor will you have to with the Helibars or even Helibars with Phil's/Murphs Wedges.  In fact, very few riser kits will require replacing or modifying the brake or clutch lines.  Most are just moving the banjo fittings from the triple tree to the riser... I don't call that "modifying" (modifying would be having to replace the lines with longer ones).  It is super easy and requires no special tools or additional equipment.
Max, do you lose any fluid doing that? I mean, is that connection an independent block just bolted to the OE location (and thus, to the riser if so required) or does the OE location/riser serve as the banjo connection block? If the latter, then the system is being opened when that location is moved.
« Reply #30 on: March 28, 2012, 08:27:07 AM »
The banjo fitting that bolts to the triple tree/risers is sealed.  There will be no leaking from just unbolting it.  Putting risers on is literally a 15 minute job with one set of hands and a beer.   ;D
« Reply #31 on: March 28, 2012, 09:47:38 AM »
Now we're talking!!  :P :-* :)
You're gonna fit in nicely here bro...  :grouphug:
Breaker19
« Reply #32 on: March 28, 2012, 11:04:16 AM »
OK, that helps. Thanks. One final question, with Murph's risers, do the brake lines get re-bolted to the risers instead of the bars themselves?
« Reply #33 on: March 28, 2012, 11:05:40 AM »
Yes, and same with the Heli risers too, you move the block from the upper triple clamp to the riser.
Breaker19
« Reply #34 on: March 28, 2012, 11:12:01 AM »
OK, that makes sense. I am assuming that the extra "length" therefore, comes from the 'long' part of the brake lines, and not from the 'short' section, between the triple tree and the handlebar ends themselves. That's where I was seeing a potential problem, those short sections have virtually no length left. But, if the fastening point is likewise raised up with the riser, then that length doesn't change and the extra hose comes from below. Am I seeing (in my mind) that correctly? Thanks.
« Reply #35 on: March 28, 2012, 11:23:19 AM »
You are exactly right.
Offline rtarp1
« Reply #36 on: March 28, 2012, 11:23:32 AM »
you can use anyones risers up to 2 inches without modifying brake lines.  i use the 2 inch risers from helibar and its just enough for me im 6ft 195 lbs.   I just ordered murphs wedge kit to go along with them , i hope it fits.
« Reply #37 on: March 28, 2012, 12:32:02 PM »
 :thumbs:
Breaker19
« Reply #38 on: March 28, 2012, 12:38:57 PM »
2", wow! Them must be some long-@ss bolts! lol... I was evaluating it yesterday while zipping around and I think 1" give or take will be fine, it's close right now at stock height, I just need a bit more. As for the wedges, I don't have any problems with the angle of the bars at all. I'm 6' like you, around 210 lbs give or take whether or not I've had a night or two of 7 and 7's or Bud Lights.. lol  8)
Thanks for the info...
Breaker19
Another dumb new owner question...
« Reply #39 on: March 28, 2012, 02:32:05 PM »
While you guys have your thinking caps on, here's another dumb-@ass question or two... where's the front auxiliary power wires? I looked in the owners manual and I can't quite grasp what it's saying as to location, under a cover somewhere? I'll need to find them eventually to wire in my Zumo550. Also, I have a GXM30 XM external antenna (the round disk) that I need to find a home, any suggestions on mounting that? I've not spent a lot of time looking for a spot, but I don't see much right out of the gate. I'm not talking about purchasing a mount for that, I can fabricate pretty well and have all sorts of tools including a welder.. I made my last one but it's designed for 7/8" round handlebars. Thanks.
And since she's such a hit, one last pic from my Avatar inspiration:
