Author Topic: Failed Fly_ectomy  (Read 9909 times)
Offline Patrick1
  • Shiny bikes get better mileage...
Failed Fly_ectomy
« on: March 25, 2012, 08:30:38 PM »
After successfully finishing the Rostra CC installation, I went after the Flyectomy in preparation for the PCV-5 installation, however
the screws seemed to be made of soft copper. I used the instructions at:  http://www.zxforums.com/forums/zx-14-forum/7500-flies-out-picture-guide.html
but stopped after 2 screws unsuccessfully.
Does anyone have a PLAN B to get them out....or am I screwed  ???    >:(
Head out on the hiway....lookin for adventure and what ever comes ma way...
Re: Failed Fly_ectomy
« Reply #1 on: March 25, 2012, 08:52:08 PM »
It seems Your plan B might Be to leave them in, return the PCV, & get a reflash on Your computer module.
I encountered trouble on My last butterfly, so I drilled the head off. I used heavy grease on the drill bit to catch the chips, & did a thorough shop vac on the air valve with a piece of clear tubing and some duct tape. It is possible to drill them all, but if you have never done anything like that before, I wouldn't recommend it.
« Reply #2 on: March 25, 2012, 09:27:24 PM »
I really like the color of that bike in the tutorial.
For me, the key to successful removal was using a JIS screwdriver. I didn't strip a single screw and applied no heat...
« Reply #3 on: March 26, 2012, 03:58:34 AM »
Did you break the screws or strip the heads? This will determine your next course of action.
Offline Gearhead82
« Reply #4 on: March 26, 2012, 07:11:17 AM »
I had trouble with a couple of my fly screws (I didn't get the JIS screwdriver like I should have) and ended up using a dremel to grind slots in them to use a flat blade screwdriver.  I think I had some success kinda hammering a Torx driver into one which gripped enough to pop it loose.  I think I had trouble with about 3 of the 8 screws.
'09 C14, Area P Full System, BMC, Flies out, PCV
« Reply #5 on: March 26, 2012, 07:30:21 AM »
Word of caution, dont hit it too hard, wouldn't want a bent shaft to add to your woes.  Is the risk worth it?  Yes, get them flys on the wall where they belong.
I do have a stock set of throttle bodies should that happen.
« Reply #6 on: March 26, 2012, 09:29:15 AM »
It is definitely worth the effort to get the flies out, hopefully you can remove them without much more pain and suffering.
« Reply #7 on: March 26, 2012, 09:37:31 AM »
 :banghead:
« Reply #8 on: March 26, 2012, 11:03:23 AM »
It's not too tough to remove the thottle bodies from the bike and get them on the bench. Much easier to work on, and you can make all the metal shavings you want.
Offline Patrick1
« Reply #9 on: March 26, 2012, 04:37:42 PM »
To answer one question: I just stripped the heads on two screws...and stopped.
This is the first I have heard of a "JIS" screwdriver. Arey the available at Ace Hardware or
else where?
I suspect for the two b-stards I will stuff some cotton balls oiled between the flys and
get the dremmel tool and drill a bit..... and apply the shopvac.
Offline gonzosc1
« Reply #10 on: March 26, 2012, 04:49:39 PM »
 :o seems like theres not many screws on the C14 that can't be striped. I pretty much can't take the wind screen off because of those damn useless soft allen screws,,,striped...
« Reply #11 on: March 26, 2012, 05:05:20 PM »
else where?
JIS=Japanese Industrial Standard
http://www.ikaswebshop.com/hojisscset4d.html
The inside radius profile of the slots are more square cut than a Phillips. Folks here have used both successfully..and unsuccessfully. The main trick is to heat an old screw driver with a torch then holding it against the screw to soften the threadlocker before trying to loosen the screw.
« Reply #12 on: March 26, 2012, 06:49:54 PM »
Some information about JIS drivers and the secondary 'flies on a C-14 here:
http://www.zggtr.org/index.php?topic=384.0
else where?
Offline fmwhit
« Reply #13 on: March 26, 2012, 07:43:28 PM »
Patrick, just curious if you applied heat to the screws before attempting to remove them,  as many of the guys had reported in the past that they applied heat directly to the screw head from a soldering iron to loosen the compound that Kawi used to secure the screws.
Another method to get the flies open without removing them is to use a GiPro TRE.
Good Luck,
Fred
Offline Cuda
« Reply #14 on: March 27, 2012, 11:15:32 AM »
IF........I was going to do remove the flys this  sounds like the way to go $$$$$$$$$
I'm going with the reflash of the ECU,  Traction control is one of the reasons I bought this bike and I would not want to hamper its use.
Gods waiting room Naples
2011 Atomic  Silver
« Reply #15 on: March 27, 2012, 11:28:04 AM »
There are several people that have removed the flies from KTRAC equipped bikes with no noticeable changes in the TC operation.
disclaimer: I am not saying that there are no changes and I do not advocate any modifications that could make the slower 2010-2012 bikes almost as fast as the 2008.   ;D
Offline Gearhead82
« Reply #16 on: March 27, 2012, 11:39:18 AM »
disclaimer: I am not saying that there are no changes and I do not advocate any modifications that could make the slower 2010-2012 bikes almost as fast as the 2008 2009.   ;D
Fixed :D
« Reply #17 on: March 27, 2012, 12:43:50 PM »
Really? Traction control and linked brakes were the reasons I bought a 2009 instead...
Offline Cuda
« Reply #18 on: March 27, 2012, 04:10:40 PM »
If you lived in Naple Fl. the heat of the 09 would not be that much fun, I was going to get a ST1300 till I learned about their heat Issues  SATAN'S CHARIOT as one owner called it . I really don't have any back roads to have fun on , there was nothing here 30's ago it's all new and flat and square, with greasy hot roads that get rained on at any time, Tropical.
2011 Atomic  Silver
« Reply #19 on: March 27, 2012, 05:18:22 PM »
Hmmm, you got sold a bill of goods then.  Those bikes don't have traction control and linked brakes.  How long did it take to find out it didn't have those options?  ;)
