Author Topic: Fuel Line  (Read 1475 times)
Offline JDM
Fuel Line
« on: March 23, 2012, 05:31:34 PM »
I am getting ready to change the fuel line to the carbs, has anyone found a easy way to make the connection to the tee at the carbs?  with out pulling them.  any help would be greatly appreciated.  THANKS JD
Offline Ron Dawg
  • a/k/a ron203
Re: Fuel Line
« Reply #1 on: March 23, 2012, 07:34:49 PM »
Long needle nose pliers and/or angled needlenose.
2014 C-14 Red
Offline redzgrider
Re: Fuel Line
« Reply #2 on: March 23, 2012, 07:47:03 PM »
I use a length of brass tubing that just fits into the tee -- it keeps the tee from rotating, and acts as a guide for the new fuel line. I lube the end of the new line with a bit of spit, then slide it over the brass tube and onto the tee. I found a very long pair of forceps at Harbor Freight that I use to hold a spring style hose clamp open. Slide the clamp over the line down to the tee, release the forceps clamp, and the new line is in place.
Offline JDM
Re: Fuel Line
« Reply #3 on: March 24, 2012, 07:26:43 PM »
I tried your technique and it made it so easy even a Turnip Truck Driver can do it.  I used a bit of heat on the end of the fuel line and some 3-in-one  and it slipped on so easy.  Thanks for the tip.  :chugbeer:
