Author Topic: First ride and: brake light sticking or not working :(  (Read 3355 times)
Offline silvermane
« on: March 20, 2012, 07:22:25 PM »
Well I finally got my new '11 Connie out today, and a driver said my brake light is stuck on.  I pulled over and sure enough, after I hit the front and rear a few times it started to work.  Later in the ride, I was warned again by another kind soul.  On/off all day it kept sticking.  Anyone else have this issue.  I looked at both switches and nothing seems to be sticking/hitting them.  HELP!  I hate to go back to the dealer for anything and especially because it's so far from me :( uhg!
'11 Silver Concours, '04 Aprilia Futura, '93 Goldwing, '97 750 Nighthawk
Offline shreveportSS
Re: First ride and: brake light sticking or not working :(
« Reply #1 on: March 20, 2012, 09:34:46 PM »
I have not had a problem with my 11...or nobody is telling me.
2011 Concours 14
2011 ZX1000GBF Ninja. Died Dec. 1st, 2012
2012 ZX1000HBF Ninja.
« Reply #2 on: March 21, 2012, 02:22:58 AM »
Happened on My 08. It was the rear switch. I adjusted it a couple of turns, and it's been fine since.
« Reply #3 on: March 21, 2012, 04:07:44 AM »
Make sure that there isn't a piece of gravel or rock stuck in the rear brake pedal shield area preventing the pedal from returning.
Offline koval68
« Reply #4 on: March 21, 2012, 05:27:36 AM »
You're suppose to adjust rear brake light switch after changing rear brake pedal travel.
There is a plastic adjusting nut on the switch body. You may have to reshape the ends of the return spring as well !
- Mahatma Gandhi
Offline 4cedars
« Reply #5 on: March 21, 2012, 09:24:15 AM »
Also make sure the front brake switch is disengaging. Especially if you have aftermarket brake/clutch levers (from China). I had a problem with the brake lever mechanism not allowing the plunger to come out far enough to disengage the switch.
 It turned out to be caused from the lack of lube in the mechanism of the brake lever and the resulting mild seizure of 2 parts.
When you pull on the front brake lever and release it there should be an audible click both ways when the switch is activated and deactivated. You will be able to do this with the bike just sitting and not running.
Just a thought, John
IBA# 45862
MTF Tourers Assistant
Offline silvermane
« Reply #6 on: March 21, 2012, 03:27:08 PM »
Fantastic input gentlemen.  I'll do the search and report my findings.  Wish me luck :/
Offline silvermane
« Reply #7 on: March 24, 2012, 07:23:36 PM »
Checked all, did make a couple turns in/out on the rear adjustment and it starting working fine.  Thanks again.  This forum stuff really works! :D
Offline momo65
« Reply #8 on: March 25, 2012, 05:59:01 AM »
Yes it does brother, love this forum.
Offline koval68
« Reply #9 on: March 25, 2012, 06:57:32 AM »
Good news!
Your bike is bulletproof and don't let anyone tell you otherwise!  ;)
- Mahatma Gandhi
