Author Topic: shock preload adjuster cap (2010-2012 model)  (Read 2444 times)
Offline jtk1531
  • Country: my
« on: March 17, 2012, 08:22:29 PM »
anyone knows how to take off the plastic adjustment cap on the shock preload adjuster?
frequent rides in the rain seem to result in a siezed up adjuster. i'm thinking of using some silicon grease to lube up the inside of the cap.
i've read about using WD-40 and other types of spray-on lubes to free up the adjuster, but i don't think petroleum-based solvents will be safe for o-rings that might get in contact with the spray liquid.
Offline momo65
Re: shock preload adjuster cap (2010-2012 model)
« Reply #1 on: March 17, 2012, 08:51:22 PM »
I don't know how to take the cap off, but whatever you do, do not use WD-40, you are going to end up with a bunch of dirt and grime afterwards, am pretty sure someone here will help you with your question.
Offline wally_games
« Reply #2 on: March 17, 2012, 09:01:59 PM »
Same happened to me and I've read that it's happened to others. I took mine back to the dealer and they had it working within 10 minutes and I haven't had a problem with it again for about 10 months.
Offline Glennn
    • Metric Rider
« Reply #3 on: March 18, 2012, 08:38:14 PM »
There is a small pin on the back side (tyre side) of the adjuster that I have read (so not done myself) you push into the adjuster which then allows you to pull the cap off.
My adjuster seized within a week of having the brand new bike that had never seen rain.  I sprayed Inox (a penetrating lubricant) up under the cap, worked it back and forth and it has been fine since.
1999 Yamaha Road Star
Canberra, Australia
CDA #390
Offline jtk1531
  • Country: my
« Reply #4 on: March 18, 2012, 11:30:32 PM »
yeah, i noticed that pin too. tried to push the pin in yesterday evening while cleaning up the bike, but it doesn't seem to budge at all. i only had a small key on hand at that time that i tried to push the pin in with.
any site-reference to where you read about pin's function? is it supposed to be pushed in when the preload's fully in or out or somewhere in between?
Offline Glennn
    • Metric Rider
« Reply #5 on: March 19, 2012, 12:04:17 AM »
Have tried to find it for you but can't seem to work my google-fu at the moment.  I seem to remember reading you had to push it through with a nail or something and then fish it out of the adjuster when dissasembled.
BUT
I didn't like what I was reading and a jammed shock adjuster on a one week old bike was bad enough I didn't want to be responsible for breaking the thing.  But still, after I gave her a squirt with the lube and got onto it with the strap wrench it has been fine.
Canberra, Australia
CDA #390
