A few times recently, my C-14 has stalled when making a quick transition from throttle-on to throttle-off coming to a stop. A good example is a going up my steep driveway with a solid throttle input for the incline, then snapping it shut for the short turn area at the top of the drive and the bike stalls. The bike is fuly warmed up when this happens and seems to be idling fine. Throttle free play is minimal. It has also happened when making a short stop at an intersection. This has occured about three time this past week.
Background: The bike is just back on the road this past week for the first time after being down for winter maintenance since mid-January. Valve adjust, coolant change, new tires, oil, etc. Other than this hiccup, the bike is running smooth as silk. Mine is a 2009 C-14 ABS with 23,700 miles on it. This cut-off had never happened before.
I will be double-checking idle speed and throttle play. Any insight from the masses?
