Well, here's a follow for whoever cares...looks like RFH and Dan were correct....I pushed the thermostat housing towards the rear of the bike and guess what?...the leak appeared from the o-ring between the housing and the log. After I put the valve cover back on and fired Connie up, there was absolutely no coolant leak....
....happy, yes!....trusting, absolutely not!
...so there is good news, more good news and bad news. First, the good....no coolant leak, but I still plan on pulling the carbs, coolant block and replacing all the o-rings. More good news; SISF exhaust cam makes Connie rev like there's no tomorrow. In conjunction with the 2 minute jet mod, this motor runs like a freakin' top!. Now, the bad....no doubt no one's fault but mine, but Connie leaks a little oil from the rear of the valve cover gasket, so I get to pull stuff apart again and reseal it.....I have no gripes though, based on how much smoother she runs after SISF exhaust sprocket!
