Author Topic: do risers for 08/09 models fit the 10+?  (Read 3786 times)
« on: March 12, 2012, 04:26:19 PM »
The bars are the same right? Or aren't they??
Re: do risers for 08/09 models fit the 10+?
« Reply #1 on: March 12, 2012, 04:42:31 PM »
I would think the bars and bolt pattern is the same but the brake and clutch lines might be different.
« Reply #2 on: March 12, 2012, 05:36:29 PM »
The bars are compatible, to the best of my knowledge.
Offline Kas
« Reply #3 on: March 12, 2012, 06:06:18 PM »
They do fit, the issue is the clearance for the glove box mounted on the gas tank.
« Reply #4 on: March 12, 2012, 07:42:45 PM »
Good point.  Although I don't think that is an issue EXCEPT for the new "Damn Potholes" risers http://www.zggtr.org/index.php?topic=7271.0  which have a big offset.
« Reply #5 on: March 12, 2012, 07:54:31 PM »
I'm asking if 08/09 risers will fit on a 10+, the 10+ does not have the center glove box so I wouldn't think that would be an issue since there's even more room there on a 10+?? Or did I misread your post?  :-\
« Reply #6 on: March 12, 2012, 08:11:18 PM »
LOL!  He misread your topic, and I just followed along with it :)
The clearance issue would only be on using risers designed for 2010+ on an older model that still has the tank-mounted glovebox.  But the only risers I know of with an interfering offset like that would be the ones I mentioned, above.  I don't think it matters with any other "brand".
« Reply #7 on: March 12, 2012, 08:23:12 PM »
No worries, I fugured as much Max.
The risers in question are Genmar 1.5" risers that are from an 08, just confirming they'll work on LivnLoud's 11...
« Reply #8 on: March 12, 2012, 08:29:49 PM »
Should be no reason they will not.  Only issues come when going from 2010 to 2009 due to box as stated.
« Reply #9 on: March 12, 2012, 08:33:48 PM »
Yep- Genmar is just a simple, straight-up riser.  Will fit any C14
« Reply #10 on: March 12, 2012, 09:18:35 PM »
Thanks for the help brutha's, that's the answer we were wanting to hear...  :grouphug:
« Reply #11 on: March 13, 2012, 07:25:57 AM »
