The '08 glovebox won't fit your '11. They moved some relays to where the glovebox was and changed the brackets on the '10's and '11's. The glove box on my '08 get awfully hot anyway.
How about a powered tank bag? Check these guys out:
http://www.rka-luggage.com/A02%20Tankbags/com%20bag%20Build%20sheet/Master%20Accessoires%20Build%20Sheet.html
Not totally correct. The glovebox will fit if you have the mounting bracket from the 08/09 and then there's some other modifications that will need to be done to the box. There's a write up on how to do this somewhere. If I locate it, I'll add the link.
Anyway, I'm looking for one myself.
