Author Topic: When a FOB is missing  (Read 5061 times)
Offline SPX
« on: March 03, 2012, 11:05:15 AM »
http://inlandempire.craigslist.org/mcy/2871073152.html
What would need to be changed in order to get that bike to start, since the FOB is MIA?
Offline IRULE
  • How sweet it is...
Re: When a FOB is missing
« Reply #1 on: March 03, 2012, 11:10:24 AM »
I don't know about a motorcycle, but should be the same concept as cars.  So, first you need to contact the dealer, order or buy a FOB, then bring the bike to a dealer, then they will program the FOB with the bike.  That should do it.
Sometime, the module might have to be replace along with a new FOB.  This is rare.
Lastly, you can always call the dealership and ask.... ;D
2009 Red Buell 1125CR
1978 Triumph Bonneville
Offline dras
  • The Invisible Man
« Reply #2 on: March 03, 2012, 11:19:37 AM »
It would need a new ECU and the fobs to go with it. Without at least one operating fob there is no way to turn on the ignition to program in a new fob. I would ask a dealer as well.
Never get too busy making a living that you forget to make a life.
« Reply #3 on: March 03, 2012, 11:21:44 AM »
IF THERE IS NO EXISTING fob THAT WAS PROGRAMMED TO THE ECU, YOU WILL NEED A COMPLETELY NEW ECU, and associated FOB, and you can then program additional FOBS.
It takes a FOB matching the ECU to allow programming additional FOBs.
sorry.
The ad also states they don't even have any KEYs for the unit, which would make me say it is a HOT POTATO..... ???
Offline So Cal Joe
« Reply #4 on: March 03, 2012, 01:58:09 PM »
Don't you also need the FOB number that was on the plastic bag it came in? As I understand it, and I could be wrong, that number is needed to program a new FOB and the only place it is listed is on the plastic bag it came in.
« Reply #5 on: March 03, 2012, 03:12:32 PM »
I believe you are thinking of the TPS...not fob.
« Reply #6 on: March 03, 2012, 03:31:31 PM »
Nope.....need that for the FOB.
« Reply #7 on: March 04, 2012, 06:26:04 AM »
If you have at least one working fob that you can use to turn on the bike, you do not need the serial number for that fob in order to program the bike to work with new fobs. Any new fobs that are to be used with the bike WILL need the serial numbers so that the bike can be programmed to work with that fob.
As stated above, if you have no working fobs then you're SOL till you get another ECU with at least one matched fob.
See the attachment below for info.
MGvalerio
« Reply #8 on: March 04, 2012, 06:43:34 AM »
Sapevate che senza pila nella FOB key è sempre possibile l'accensione del motore.
Did you know that without a battery in the key fob is always possible to the ignition of the engine.
Visibile tra 30 minuti
http://youtu.be/4TeDQA5qZSI
MGvalerio. 8)
« Reply #9 on: March 04, 2012, 06:51:44 AM »
Looks like the above video needs a matched fob to make it work.   :o
MGvalerio
« Reply #10 on: March 04, 2012, 06:58:06 AM »
Non letto 30 miniti ,poi la FOB parte. >:(
« Reply #11 on: March 04, 2012, 07:49:25 AM »
No need for the mad face, when I posted my comment your video wasn't working.
MGvalerio
« Reply #12 on: March 04, 2012, 08:42:52 AM »
Sorry it was not what I wanted to understand: - [... excuse: D
Scusami non era ciò che volevo far capire :-[...scusa :D
MGvalerio. 8)
« Reply #13 on: March 04, 2012, 10:30:25 AM »
Without a battery in the fob you can start the bike with the rfid part of the fob held against the ignition switch which is what the video shows.  Good info for the newbies that don't read the manual.
« Reply #14 on: March 04, 2012, 10:34:19 AM »
And us oldies that don't, either
Offline W14
« Reply #15 on: March 04, 2012, 02:55:01 PM »
+1, didn't know that
« Reply #16 on: March 04, 2012, 03:04:45 PM »
Respect the manual! ;)
« Reply #17 on: March 04, 2012, 03:26:00 PM »
Wait for it.....
Theres a manual?
« Reply #18 on: March 04, 2012, 03:26:49 PM »
Why I oughta ........!
« Reply #19 on: March 05, 2012, 04:25:57 AM »
Yeah, I think that you should!
