Hi all. Anyone know what the torque is for the header to head nuts? I looked in my Clymer and factory manuals and cant seem to locate it.
Finally got around to putting my ceramic coated headers on, and I guess now the rest will have to wait until I can figure this out. I guess there is always tomorrow....
Thanks in advance....also, if someone knows where it is in either of those, let me know....maybe I just skipped over it, but in the Clymer, most bolt torques are at the end of the chapter discussing whatever it is you are working on. In this case, its all carb specs.
Thanks guys. Already back together. Well, minus the coolant anyway.
BTW, not to argue with the manual, but you do NOT need to remove the upper fairing to get the radiator and mount off. It would probably make it easier, but its not necessary. Id just about bet you wouldnt have to take the radiator out either, but the bracket has to come out, and its much easier to remove that with the radiator out of the way.
