Author Topic: Mounting option for Tom Tom rider gps  (Read 3808 times)
Offline Texanrider
  • There's no excuse for what I am about to do...
« on: May 19, 2011, 07:24:33 PM »
Just bought one for a great price on eBay and was wondering if anyone had any mounting recommendations. If you have pics, even better.
Thanks
09 Boulevard C50
95 Kawasaki Concours
Offline Damn Potholes
  • AdvancedSportTouring.com
    • Advanced Sport Touring
Re: Mounting option for Tom Tom rider gps
« Reply #1 on: May 20, 2011, 08:31:50 AM »
This isn't a GPS but it could get the mental juices flowing.  This is my portable satellite radio.  I bent up a piece of aluminum that I bought from the Home depot and bent and shaped it with a little propane torch and a bench vise and metal file.  I bought a longer bolt and put 3 flat stainless steel washers underneath it so it wasn't crushing the plastic.  This allows you to tighten it down really well.  I plan on eventually replacing the plastic washer on top with a stainless one but haven't gotten around to it.  I attached a belt clip so that I could remove the radio really easily.  Having the bend and the leather case really absorbs the vibrations and have had no problems as of yet.
I plan on attaching a ram ball to the adjacent hole and mounting my Garmin.  I haven't found a ram ball that has the same hole diameter but I have seen ram balls that mount into a flat base and have 2 mounting holes.  In that case, all that would be required is a longer bolt and a long ram ball arm to get it high enough to be in view.
Hope that helps
My parts are forged with voodoo curses and unicorn tears.
« Reply #2 on: May 20, 2011, 08:35:11 AM »
Techmount
Offline flippedr6
« Reply #3 on: May 20, 2011, 08:41:41 AM »
The Tom Tom Rider should have come with Ram mount options.  mine came with all the stuff I needed from Tom Tom.  The only thing I did was add a Ram ball to my handlebar risers.
« Reply #4 on: May 20, 2011, 08:44:12 AM »
RAM mount.
Offline Tremainiac
« Reply #5 on: May 20, 2011, 10:27:11 AM »
I've the TomTom Rider2 mounted on the bracket from Moma Kawa.
I seem to have a problem with the wire that hooks up to the bike.  :-\
Not charging. Works fine in my truck.
Will take pics over the weekend.
« Reply #6 on: May 20, 2011, 10:55:28 AM »
Offline So Cal Joe
