oops - missed some questions - here ya go -
Turn around is immediate. I have cams ground and ready to go. I have a core return program in effect, so when you do the swap and ship your old cams back, I refund the core deposit.
as far as using my advanced exhaust cam sprocket aND the new cam grind, I don't advise it. the advanced sprocket is designed for the stock cam profile, the replacement / torque cams are appropriately timed already, just install in the specified position on the sprockets and you're done. Keep in mind that my advanced exhaust cam sprocket still has all the nessessary stock timing holes, so if you have my sprocket you just shift to the round countersink holes when using the new cams and you're good to go.
Jetting - the Ocampo bike does have my dedicated 2 minute mod jet kit installed. Stock jetting will work, the 2mm jet kit works a bit better - HTH, Steve
