Author Topic: Thanfully the Traction Control has an off switch...  (Read 10661 times)
Offline jqram35
  • 2012 C-14 Candy Arabian Red
« on: February 14, 2012, 01:39:29 PM »
First ride since my accident. Got a over 200 miles on her so I got into the throttle a few times today. I think she is a beast. Feels better than my FJR. Pinned the throttle in second and the front came up causing the traction control to take over abruptly and said NO Sir none of that LOL. Pulled over and turned that crap off. I do wish I didn't have to turn it off every time I started the bike...So far very happy with my new purchase
« Last Edit: February 14, 2012, 02:22:49 PM by jqram35 »
Jeff
Re: Thanfully the Traction Control has an off switch...
« Reply #1 on: February 14, 2012, 02:13:44 PM »
I don't have that problem with mine.
Offline Kiwi Graham
  • Country: nz
« Reply #2 on: February 14, 2012, 02:20:20 PM »
Wish you could turn off the ABS :-(
Offline Gearhead82
« Reply #3 on: February 14, 2012, 02:22:19 PM »
I don't understand all this talk of 2nd gear wheelies lately.  Even with some serious clutch abuse I can barely get mine to do a little bunny hop in 2nd gear unless there's a dip in the road or something.  And that's even with the fastest red color.  1st gear is a whole 'nother story though. . .
« Reply #4 on: February 14, 2012, 02:22:41 PM »
My ABS works perfectly fine as well.
Offline jqram35
« Reply #5 on: February 14, 2012, 02:26:40 PM »
All I know is the power dropped off no where near the rev limiter and the nose was coming up quick.  I wouldn't mind it if it wasn't so abrupt. I that happened in a corner due to wheel spin and loaded the front tire that could spell serious trouble. Think that will stay off till I do so rain riding and more testing...
Jeff
Offline Kazairl
« Reply #6 on: February 14, 2012, 02:28:48 PM »
 Disconnect one of the speed sensors. Problem solved.
 I've never been able to do a power wheelie in any gear. I have to use the clutch.
Offline Gearhead82
« Reply #7 on: February 14, 2012, 02:39:14 PM »
That was the case with mine too until I added the Area P full system.  Now it comes up all by itself in first without hesitation.
« Reply #8 on: February 14, 2012, 03:01:31 PM »
My front wheel will go up standing still, especially fully loaded with a top case.  Fully stock system.  I don't even have to have the engine running.
« Reply #9 on: February 14, 2012, 03:39:32 PM »
How about with the center stand up?
« Reply #10 on: February 14, 2012, 04:06:31 PM »
KiPass.    :D
« Reply #11 on: February 14, 2012, 04:17:28 PM »
 :rotflmao: :rotflmao: :rotflmao:
« Reply #12 on: February 14, 2012, 05:03:55 PM »
Why would you want to complicate this simple procedure?
« Reply #13 on: February 14, 2012, 07:53:22 PM »
The 08/09 models have no problem lifting the front end. ;)
Offline Z71
« Reply #14 on: February 14, 2012, 08:26:52 PM »
Why is that?  Can you be more specific?
« Reply #15 on: February 15, 2012, 03:58:25 AM »
 :popcorn:
Offline cablebandit
« Reply #16 on: February 15, 2012, 07:37:30 AM »
Why pull over.  You can turn off traction control at any speed, unlike the linked brake pressures.
« Reply #17 on: February 15, 2012, 07:44:33 AM »
Why is there so much skepticism about pulling the front end in second gear?  I'm not saying I can do a 12 o'clock wheelie in second but it will loft and carry fairly easily, no clutch abuse needed.  Every bike and especially riders have differences.  I think most of it is weight distrobution and what kind of tune/exhaust is being used.  That or the fact that I have the fastest 08 on the internet....... ;D
Offline jqram35
« Reply #18 on: February 15, 2012, 07:47:35 AM »
Thought you had to be stopped...
Jeff
Offline basmntdweller
    • The Profile Brotherhood
« Reply #19 on: February 15, 2012, 08:47:22 AM »
Lack of wheelie performance is my biggest complaint on my '09. In first, it has to hit a bump or some other road issue for it to come up. It always feels as if it is on the verge of coming up but it hasn't yet. It may be because I tend to ride "nuts on the tank" and fully geared I am pushing 250lbs.
I am hoping the new full exhaust, flyectomy and PCV will cure this one minor fault on my connie.
Matt
'09 C14
'98 DR-350
'03 Honda CBR600RR track bike
