I'm getting into foggy territory here, but I believe in addition to the splines on the hub, you also should pull the snap ring off and disassemble and lube some of the bushings inside. It's been a few years since I've done it but I found the lube that was in there to be pretty dry and glad I pulled it apart. This is on the wheel.
