Author Topic: Onboard computer display mod  (Read 48170 times)
Re: Onboard computer display mod
« Reply #80 on: February 07, 2012, 06:41:25 PM »
The last part of my last post was semi-facetious, I am already way ahead thanks to this thread. Frankly I am impressed that someone could point the way to get as far as we have. I have a friend who used to work for NASA who worked similar magik on my old C10 J-Box, I may consult him. But  before I start poking and prodding I will take a look at the wiring diagram. Bud's suggestion is a great start. As for the switch it will need to be a momentary, otherwise the mileage gets reset to zero.  ???
Offline marku8a
« Reply #81 on: February 07, 2012, 10:33:23 PM »
So my final solution was to use the Flash To Pass (FTP) switch. Ground to the black/yellow wire to the horn switch. You need to loosen the turn signal switch to get to the horn ground wire.
Thinking that I was going to add a switch as opposed to using the FTP switch I purchased a couple of the previously recommended switches...
http://www.gamainc.com/site/epage/128634_941.htm
These will fit with no problem, have a good crisp tactile feel and look OEM.
A sweet mod at almost cost! Bring on the ODO mod!!
Mark
2009 C14 Red
Offline marku8a
« Reply #82 on: February 07, 2012, 10:37:18 PM »
Sorry. I meant ...A sweet mod at almost no cost!
Mark
2009 C14 Red
Offline OCK913
    • The Orlando Riders Club
« Reply #83 on: February 08, 2012, 03:19:44 PM »
Just wanted to update and say that I completed my display mod last night and everything works perfectly and I am very pleased with the result. A HUGE THANK YOU to Lord Frederick for the instructions and everyone else who added follow-up. All in all, I spent less than $5 and probably 2 hours from the time I turned the first screw til the time it was all buttoned up.
All :hail: Lord Frederick
            2009 Kawasaki C14 - Black
Offline BudCallaghan
« Reply #84 on: February 08, 2012, 08:18:03 PM »
Thanks Bud, as soon as I read that I was  "DOH!"  I checked it before I left for work and I am good to go. I will work on the connecting it to the display tonight.
Congratulations!
We're located at opposite corners of this country, perhaps that explains why you say "DOH" and I say, "DUH".  I've always said "DUH" and never heard otherwise until the arrival of Homer Simpson.  Are you a fan of his?
Offline Kwikasfuki
    • Uk GTR Forum
« Reply #85 on: February 09, 2012, 03:58:12 PM »
I'm quite impressed with my non waterproof switch. Got caught in a downpour and it behaved perfectly.
I still have my grand plan of replacing the display with a custom one, once I can crack all the canbus codes.
« Reply #86 on: February 09, 2012, 07:53:06 PM »
In dash GPS?  That would be an interesting project.
« Reply #87 on: February 09, 2012, 08:02:04 PM »
 :popcorn:
Offline Kwikasfuki
    • Uk GTR Forum
« Reply #88 on: February 10, 2012, 06:30:00 AM »
More than that. A fully inbuilt android or linux based device.
Of course you can put one in a holder and shove it on your handlebars but its not quite the same thing
« Reply #89 on: February 10, 2012, 06:35:32 AM »
Sounds like a great (highly technical) project.  Good luck sir.
« Reply #90 on: February 10, 2012, 04:36:16 PM »
+1,000,000 !!!
Offline Kwikasfuki
    • Uk GTR Forum
« Reply #91 on: February 11, 2012, 06:55:48 AM »
To be honest, doing a customised onboard computer whether it be android or linux based isn't that hard.
The hard part is know what protocol Kawasaki use in their CANBUS and writing the protocol code.
So:
1. on the handlebar there would be some sort of joystick control to navigate the menus
2. the onboard computer would allow:
           a. customised display (so if you wanted to have TPS with battery voltage and temperature you could do)
           b. be in colour
           c. have bluetooth functionality
           d. ability to install applications e.g. music player
           e. integrated sat nav
3. and a ton of other goodies i've not thought of.
4. Use a beagleboard or some other small form factor board
5. Must have low power consumption
6. USB to copy music/data to the internal SD card
Obviously would need to display Kawasaki system errors etc.
Its not rocket science. The hard part is the CANBUS protocol. From my research the ZX14 chaps are trying to decipher the codes as well, and they should be the same as the Concours. If anyone here has the KDS database, that would help ;). The manufacturers of speedohealer are developing their own low cost diagnostic kit for Kawasaki (sniffs messages on the CANBUS and decodes them). Once I have access to this kind of toolset it will make life easier.
If I do get it done, I'm just dreading the size of the writeup for people to do the customisation themselves.  If people are interested in this I don't mind giving the project a bit more focus. At the moment its more for me to polish up on my technical skills.
« Reply #92 on: February 11, 2012, 07:35:08 AM »
Would not the canbus code be the same in each computer on the bike? A company like Guhl Motors,who has cracked the code in order to reflash the ecu might be able to help. On a different front a company called Hexcode has cracked the canbus on BMWs.
http://www.hexcode.co.za/
Offline Kwikasfuki
    • Uk GTR Forum
« Reply #93 on: February 11, 2012, 09:45:08 AM »
Actually, you may be right. Doing a bit more digging I found this product available: kawasaki 4 pin - 16pin obd2 adapter.
This suggests an ODB2 scanner could be used and therefore Kawasaki are following the standards.
Offline jjnorc
  • 2009 C14 Non-ABS. Red.
« Reply #94 on: February 11, 2012, 05:35:58 PM »
Awsome Mod ;D
It was bothering me, having to lean up to change the display.
Thought I'd share some pics.
Because turning doesn't suck.
Offline C14-Pilot
  • Riding Pushmountain Road In Arkansas
« Reply #95 on: February 11, 2012, 07:34:32 PM »
Looks really nice!
Where did You attach the ground wire?
I have ordered the switch and will be doing this mod next week.
Thanks,
C14-Pilot
2008 Kawasaki Concours 1400, 2006 Kawasaki Vulcan 900, 2005 Kawasaki Vulcan 750
1980 Yamaha 650 Maxim,1977 Kawasaki KZ 400 Deluxe II,1973 Honda 250 Elsinore
« Reply #96 on: February 12, 2012, 11:07:07 AM »
Awesome Mod ;D
Where did you acquire this nice looking switch?
Offline jjnorc
« Reply #97 on: February 12, 2012, 11:28:23 AM »
Looks really nice!
Thanks,
C14-Pilot
I simply ran a short peice of wire out of the bottom of the switch housing and clamped it to the handle bar.
I clamped it between the cluch clamp and the switch housing. I may drill and tap the handlebar inside the housing area in the future if I have problems loosing ground. A small machine screw would fit.
Offline jjnorc
« Reply #98 on: February 12, 2012, 11:33:08 AM »
It's the one from Radio Shack mentioned a few pages back in this thread.
Mounting it was the hardest part of the whole project. I put the retaining ring on the inside of the switch housing half and marked the center with a center-punch. I drilled a small pilot hole from the inside then used a step drill bit from the outside.
Offline Kwikasfuki
    • Uk GTR Forum
« Reply #99 on: February 12, 2012, 04:29:11 PM »
Awsome Mod ;D
The switch looks part of the furniture. Good choice.
