Author Topic: Sonics vs Progressives  (Read 3770 times)
Offline timsatx
« on: January 26, 2012, 10:47:51 AM »
I plan on overhauling my front end. I know the oil needs to be changed so I am going to take it apart, put in new drain holes, and put it back together. I am trying to decide which springs I might want to get. What is the prevailing thought on the springs and what are the differences that might drive the decision?
Re: Sonics vs Progressives
« Reply #1 on: January 26, 2012, 10:51:30 AM »
I have the Progressives which used to be what most used.. But I think the current favorite is the Sonics.
If you decide on the Sonics, I have a new set in the garage. (1.1 I think) Mebbe we can work out a deal?
Offline kzz1king
« Reply #2 on: January 26, 2012, 06:44:28 PM »
So how do you like the progressives? Are they a big improvement over stock? The bike I just bought came with a new set in the box.
Wayne
2010 CONCOURS
1974 Z-1
Offline Summit670
« Reply #3 on: January 26, 2012, 07:03:49 PM »
I was wondering the same thing, which springs are preferred.  I thought I saw somewhere that one had to add spacers to one of them, maybe both brands (not progressive).
I've got progressive now, but have had for at least 15 years.  Maybe they are getting soft but I still run about 10# of air (1987 model) because I like a firmer ride and for the front end to sit higher.
Arctic Cat M8 163 rules
« Reply #4 on: January 26, 2012, 07:28:32 PM »
Wayne
The Progressive branded progressive spring is better than the stock spring but not by much at all as it still allows for far too much brake dive or rapid compression under big bumps in the road. The Concours is a big heavy girl and her smaller sized front end takes a lot of abuse and in my opinion is better served with straight rate springs, reasonably light weight oil, perhaps enlarged damping holes or better yet tuned with Cart Emulators, also be sure to not put in too much fork oil as too high of a level will make her ride harshly due to over compression.
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
« Reply #5 on: January 26, 2012, 08:16:32 PM »
I think Ma Kawasaki put in soft, dual rate springs to compensate for the damper rod's harsh compression damping.
Sticking in stiffer springs, either constant rate or 'Progressive', may reduce brake dive, but it will make the overall ride harshness worse, because what you feel when going over a bump is the sum of the spring compression force and the compression damping force.
The way that makes sense for me is cartridge emulators, for compression damping that's less harsh, coupled with stiffer springs to better control wheel motion and dive. In fact, I installed emulators first retaining stock springs, looking for increased comfort. Only later did I replace with 1.0 kg/mm Racetech springs for better road holding in bumpy turns.
Offline jim snyder
« Reply #6 on: January 26, 2012, 11:16:34 PM »
I put progressives in mine and took them back out within two months and sold them. They were slightly better
than stock but still had way too much brake dive. Went back with the Sonic 1.1's and still satisfied with them.
Offline cmoore
« Reply #7 on: January 27, 2012, 04:11:33 AM »
I have the Sonic 1.1's. I put 'em in about 4 years ago and have been very satisfied with them. Much smoother ride and better handling. A little stiff at slower speeds but I don't care about that. The stock springs were crap.
2010 C14
Dallas, Texas
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #8 on: January 27, 2012, 05:14:35 AM »
 I ran sonics, but then learned to cut the stockers to get the exact ride I wanted. it's easy to do, just cut about 4" from the tightly wound end, flatten it on a bench grinder, and then install a 1.25" washer and a 4" length of PVC. If that's still to soft, clip another inch off. Easy and basically free. Steve
Offline kzz1king
« Reply #9 on: January 27, 2012, 06:24:54 AM »
That is what I had done on my 86 Steve and liked it. My 01 came with the progressives but they are not installed. I have to look to see how they are wound but has anyone cut/spaced these? If I can't get a few bucks for them I may as well do something with them.
Wayne
PS I am sure we have similar roads as Florida. Lots of straight miles and the curves are generally long.
2010 CONCOURS
1974 Z-1
Offline timsatx
« Reply #10 on: January 27, 2012, 09:13:21 AM »
Thanks Ted, I will keep that in mind. It will be at least two or three weeks before I decide. I have a list of things I need to do to my bike. The forks are one. I also have to give it a tune-up and probably even work on the carbs.
Offline Cholla
« Reply #11 on: January 27, 2012, 11:48:32 AM »
I've been waiting on jokes aout a hedgehog (not Ron) and an overly made up gal selling insurance.
I liked Progressive springs with 15 wt. oil.
Offline SmokinRZ
« Reply #12 on: January 30, 2012, 08:38:26 AM »
I have progressive springs.  I liked the smooth ride of the stockers but the brake dive was crazy.  I weigh 180 and wanted a smooth ride, plus I had progressives in my previous concours so I knew how it would ride.  Cutting the stockers would probabaly accomplish the same thing.
2008 Concours
2005 Concours (gone)
1992 Concours (gone)
1998 R1100GS
Offline elvin315
  • Global Moderator
« Reply #13 on: January 30, 2012, 01:09:36 PM »
Read the SUSPENSION FAQs for a comprehensive overview of fork upgrades.
http://www.zggtr.org/index.php?board=27.0
This one briefly reviews the options. The other articles go into more details.
http://www.zggtr.org/index.php?topic=653.0
