Alright OED riders -- how many of you have ever "holed" a piston from detonation? EVER? Right, just like I thought !! I owned a '68 Triumph Bonneville that has high compression pistons and it "knocked" like a can of BBs on hot days under any type of moderate acceleration even on high octane gas and I rode the wheels off that bike and it never holed a piston in all the years I owned it (misspent youth) I wish I still had it today. That engine was air-cooled, had points and condenser ignition, Amal carbs and certainly NO knock sensors. Yeah, I tried to jet it "fat" (rich) and retarded the ignition as much as possible -- BUT no holed pistons. I also owned two (2) Kawasaki Mach I 500s with high compression, expansion chambers, and lean jetting. They also were notorious for detonation and holing pistons, and yet I rode the rims off my two and again NEVER holed a piston (did seize one twice in the same day though) from detonation.
I guarantee that none of you will ever "hole" a piston on the modern, water-cooled, fuel-injected, computer-engine-managed C14 from using 87 octane gas -- EVER.
Now if some of you just feel the need to appease your OCDness that is your business, but quit trying to scare everyone else about this issue even if you still jump when you see your shadow and can't sleep without your nightlight on.
We can all read the manual -- there is no need to continually recite it to the literate
