I'm sure that you're right but I was talking about my '12 Jetta TDI Sportwagen.
You didn't say that, but I guess that's part of the point. I have read literature from different sources claiming that newer vehicles can go longer before needing an oil change because they have better fuel metering/better design/better everything which makes them cleaner running.
Well,my old VW low tech diesel, made in '02, was spec'd by VW to 10k mile intervals, with cheap pseudo syn oil. If an 11 year old car can run 10k miles on cheap oil, it kind of makes your '12 (which requires $$$ 507 oil, I think that Mobil 1 ESP stuff at Pepboys is almost $10 a bottle
) look silly.
To make matters worse for me, I have a different ecm chip and large Bosio injectors, which can make thing s bit smokey when you floor it. Smoke= more particulates in the oil which is bad for oil life. To balance things out, I disconnected the egr which should help oil life (egr in these old TDI's will eventually clog up the intake).
Got almost 170k miles on the car, never have to add oil between oil changes.
