Author Topic: Time to buy rear tire - which size 190/50 or 190/55  (Read 24429 times)
Offline jjsC6
Re: Time to buy rear tire - which size 190/50 or 190/55
« Reply #20 on: January 18, 2012, 06:06:43 AM »
I went to a 55 series tire about 6,000 mile ago and I'll never go back to a 50.  There is zero downside and plenty of upside.  No need to try to explain it with physics, it just works.
BTW, I pull both wheels off together all the time to take them to my dealer.  I just put a floor jack under the front of the engine, and put a tool box under the forks.  I don't tie it down or anything.  It's not going anywhere unless you plan to do other work on it while the wheels are off (which I never do).
Jim
2010 Concours - Sold Feb 2013
Current bikes....
Offline cablebandit
« Reply #21 on: January 18, 2012, 09:21:51 AM »
That's not safe for me (notice didn't say "to" me...sure others can do that safely).  I'm that guy whose bike would take a dump.
Perhaps you should re-evaluate the safety of riding a motorcycle.
That bike has 4 points of contact including straps.  I'd venture to say that bike is much more stable than it ever will be just parked in the garage on the side or center stand.
Offline roadie
« Reply #22 on: January 18, 2012, 10:43:55 AM »
?  You take me applying self deprecating humor as me needing to re-evaluate riding a bike?  Come on.  I simply said it is not for me.  Perhaps you need to reevaluate your delivery.
BTW...yes, lots of points of contact, and more stable than a center stand...just scares me to look at (me).
Will
Offline Gearhead82
« Reply #23 on: January 18, 2012, 11:18:44 AM »
Another easy way to keep the front off the ground is to just re-install the front axle and put a jack stand underneath the axle.
Offline roadie
« Reply #24 on: January 18, 2012, 11:34:51 AM »
good point! I like that.
Will
« Reply #25 on: January 18, 2012, 02:16:50 PM »
+ 55  handles significantly better than the 50
+ 55 appears to increase the accuracy of the speedo
+/-  55 creates SLIGHTLY taller gearing - lower RPM's at cruising speed / little slower out of the hole IMO
+1.
Most importantly for me the 55 handles much better and turns in quicker.
« Reply #26 on: January 18, 2012, 04:04:33 PM »
That is actually pretty secure what with those nylon straps and all- I hang my bike on an auto jack under the engine and a milk crate under the forks. Then again, no one uses my garage but me so I can leave something there without the worry that it will be disturbed, bumped, etc. Someone with kids or anyone else using the garage probably should secure the bike better than I do. And, of course, I set Kirby out to keep and eye on things so between him and KiPass I figure nothing could possibly go wrong.  ;)
Offline OCK913
    • The Orlando Riders Club
« Reply #27 on: January 28, 2012, 12:49:13 AM »
I just put new Pilot Road 3's on mine and went with the 190/55 in the rear. I'm not a super aggressive rider but I can tell a difference. Not sure how to explain it.........it just feels better.
            2009 Kawasaki C14 - Black
Offline JamminJere
« Reply #28 on: January 29, 2012, 02:49:58 PM »
+1.
All of the above... AND dont forget how much easier to get up on the center stand... :)
JJ
« Reply #29 on: January 29, 2012, 03:06:21 PM »
My dealer in town charges me $20 for each wheel and that includes balancing.  I bring in the wheels of course.....without the bike.
