Author Topic: The downfall of ABS....HUH?  (Read 9687 times)
Re: The downfall of ABS....HUH?
« Reply #20 on: January 18, 2012, 12:25:38 PM »
I use my rear brake, but only in addition to the front. I'm amazed at how many riders never practice braking skills before they need it. Those are the ones you find in a ditch just after the long skid mark abruptly stops. You should use your rear brake so often that it is second nature, so you know how much you can use without locking it up. You need to practice this so that in an emergency you WON'T lock it up. No I don't have ABS, I bought the 2009 over the 2010 because I didn't wan t linked brakes. Personal choice. I also tend to go for the simpler of two pieces of machinery as long as the simpler one does what it is I want, and the 2009 does.
Practice is better than complacency, whether you have ABS or not.
The 08/09 ABS systems are not linked.
Offline lt1
  • 2008 C14
« Reply #21 on: January 18, 2012, 01:21:00 PM »
After purchasing my 08 C14 ABS, I thought that I would never buy another non-ABS bike.  But there were just too many cool old bikes w/o ABS, so I relented.  I still don't think I'd buy a new bike w/o it.
ABS makes it easier to practice hard braking.  You learn to modulate while reducing the risk.  It is not hard to switch between and ABS and a non-ABS bike, nor to switch between different styles of bikes.  You just have to put enought time on each so that riding that bike becomes natural.  Usually it takes well under 1000 miles to fine tune the muscle memory for each bike.
So yes, ABS is wonderful, but it is not a good reason to miss out on riding some wonderful bikes that don't have it.
Eyes, Brain, Hands.  Repeat.
« Reply #22 on: January 18, 2012, 01:37:45 PM »
I agree to that but it's my wife I need to convince....
« Reply #23 on: January 18, 2012, 02:04:50 PM »
ABS rocks, stret or track.  And i used to be anti-ABS till i got open-minded and bought a bike with it
Offline Sea Level
« Reply #24 on: January 18, 2012, 02:30:23 PM »
I'm not sure what you mean here. I share your sentiments regarding the rest of your post, but if you are saying here that you should learn to modulate ABS brakes, I would have to disagree. ABS is about preventing wheel lock, and no human can modulate (apply and release) the brakes as quickly or precisely as a computer. So an ABS system gives the rider the luxury of braking as hard as they want without fear of lockup. Modulation would only occur during the normal course of minimal braking that is a part of proficient riding. Wouldn't you agree?
The linked aspect of the ABS system on the Connie is another matter. I wish there was an on/off switch for that, as I'm not always happy with the computer's use of differential braking. But for the most part I am used to it and I just use my right foot to assist the system prior to entering curves, as I've said, to quiet the suspension during the turn.
Offline lt1
  • 2008 C14
« Reply #25 on: January 18, 2012, 02:43:45 PM »
My apologies, I thought it was fairly obvious.  It is true enough that in a panic situation, you can grab/stomp the ABS and let the system modulate.  That is not what I was discussing.  I was discussing practicing hard braking.
With normal braking practice, you brake harder and harder, gently approaching the pavement and tire traction limits.  With ABS, the practice is the same, but instead of the tires sliding, the ABS engages.  So you practice under different conditions to become familiar with how the bike, suspension and tires behave, with less risk of crashing.  Same practice, but there is a safety net with the ABS.
With proper situational awareness, the odds of needing the skills drop, but it is better to keep the skills sharp.
« Reply #26 on: January 18, 2012, 03:00:45 PM »
They make solo seats.
Offline Sea Level
« Reply #27 on: January 18, 2012, 04:21:31 PM »
Ah, I agree with all of that. Things that are obvious to other people aren't always obvious to me, but I make up for it with a winning personality.    ;D
« Reply #28 on: January 18, 2012, 04:43:28 PM »
 :thumbs: :thumbs:
Offline PH14
« Reply #29 on: January 18, 2012, 09:49:44 PM »
I know, my choices were a 2010 and a 2009 non-ABS, I went with the 2009.
Offline feelergaugephil
« Reply #30 on: January 19, 2012, 01:51:22 PM »
It was the OP (original poster):   "I ride an 03 ZRX 1200R without ABS, the back wheel locks up under heavy braking!!!!!!!!!!"  Although he later says he was kidding, that sentence indicates over-breaking on the rear.   And in context, he was talking about panic stops where ABS saved him.
Then Texrider added "Seems as though he means being used to the ABS causes him to be heavy footed on the non ABS bike..."
Exactly......................... I was also reffering to, (well not many people can do this) is heavy braking IN THE CURVE without the bike standing up straight or throwing you off, sometimes I'll get in a curve too hot and have to use the rear brake, the 1200 would spit me off, but the 1400 pulses nicely, (not every curve, just the ones I went into too hot)
I'll wear the back brakes out twice as much as the front, I rarely use the front brakes in a curve, seen sooooooo many people go down using that method.
Dont take my LOW post count as being a new Connie owner, I have been with the "other site" before it imploded........
13 Connie dressed in blue
Offline lt1
  • 2008 C14
« Reply #31 on: January 19, 2012, 05:34:58 PM »
To many of us, the bolded statement would be evidence of overusage of the rear brake, and of poor braking techniques and practices.  Good luck.
« Reply #32 on: January 19, 2012, 07:05:18 PM »
Been riding 30 years, still here to show that I'm still alive..........
« Reply #33 on: January 19, 2012, 07:08:55 PM »
Been posted before, but it's worth reading again.  I wonder how many riders have been touched by this type of riding?
http://www.motorcyclistonline.com/flashback/122_0911_the_pace_nick_ienatsch/index.html
Offline Z71
« Reply #34 on: January 20, 2012, 09:58:31 PM »
Theoretically non-ABS bikes are faster because they are lighter.   :)
Offline PH14
« Reply #35 on: January 21, 2012, 08:23:14 AM »
+1 :o
