Author Topic: My least favorite part of my C-14 has now let me down, KIPASS failure  (Read 37034 times)
Offline lolife
My 09 has almost 23,000 miles of worry free, great riding.  I was riding home Sunday when  I stopped for gas & my Kipass wouldn't work.  I banged on the switch with the back of my hand & got it to free the switch.
After arriving home, nothing. I removed the little panel on the LH side & can unplug the grey connector to get the bike to the dealer.  Thankfully its still under warranty for another 6 months or so.
I know some are saying "damn, another Kipass thread".   :o
When I bought my C-14 I always wandered why not just a regular key switch?  I'd rather keep up with a key than a fob, key switches work & really its kinda hard to improve a key switch.  I don't understand why so many car manufactures are going away from keys?   :-\  My wife's 2012 Durango doesn't have a key either.
I just thought I'd report here.  If anything it gets a tad of frustration out.  Its supposed to be 65-70 degrees next weekend & I doubt I can get my bike back in 5 days.  I may ride it unplugging the connector.   8)
Thank you for listening
« Last Edit: January 17, 2012, 04:44:42 AM by VirginiaJim »
Re: My least favorite part of my C-14 has now let me down
« Reply #1 on: January 15, 2012, 11:30:17 AM »
I look forward to hearing the fix, not bashing by any means.
« Reply #2 on: January 15, 2012, 11:33:41 AM »
If it's failing consistently then I say "Good show, ole chap!".  It's the intermittent ones that the dealer is reluctant to 'fix'.  Let us know what they do.  Some say they are replacing the spring with a stronger one.  I wouldn't let them off the hook if all they do is spray it 'clean'.
Offline lolife
« Reply #3 on: January 15, 2012, 11:37:12 AM »
If it's failing consistently then I say "Good show, ole chap!".    I wouldn't let them off the hook if all they do is spray it 'clean'.
Yes, its broken completely.  I've banged on it with my hand but I'm not using the ol' K-Rock.   :D
Spraying it clean is not a fix.  That's a band-aid.  I won't settle for that w/o an argument.
Thank you for the replies
« Reply #4 on: January 15, 2012, 12:07:58 PM »
good luck and keep us posted. Totally agree with the good ol' key. I hate hating, but I hate technology for technology's sake.
« Reply #5 on: January 15, 2012, 12:17:37 PM »
Sorry you are having a problem.  I don't think they fixed the spring issue until the updated 2010 model year.
Keyless is *wonderful* on my car.  I have one fob, I keep it in a fanny pack or briefcase and never even think about it.  I love it.  I don't have to mess with ANY keys, EVER.  And the ignition is a push button switch.  I can open doors, trunk, even the gas filler, AND start the car, without ever touching the fob.
But on the C-14, it really does nothing for me at all.  Since it does not unlock the gas tank, and does not unlock my bags, I still have to carry a key, or mess with the silly stovekey.  And there isn't an ignition button, it is still a key switch, so I have to fiddle with something to get the bike ready to start.  And it doesn't lock or unlock the steering automatically, so you have to press, then wait, then press (but not too soon) and try to turn, etc.   It has almost all the disadvantages of a mechanical system (difficult to use, mechanical failure, multiple keyholes, manual switching, etc), all of the disadvantages of an electronic system (complex, expensive, batteries, etc).
Keyless on a bike is a good concept, if done correctly.  KISPASS is neither.  Let the flaming begin!
Offline Tremainiac
« Reply #6 on: January 15, 2012, 12:27:08 PM »
I thought I had a KIPASS issue, turned out to be loose intermittent ground at the battery.
 :D
And since I have to carry a key for the bags, top box and house, I think of the stove bolt key as my spare. Hidden in plain site.  :stirpot:
Offline Supatramp
« Reply #7 on: January 15, 2012, 02:18:29 PM »
I was 1200 miles from home when my problem reared it's ugly face, but was lucky enough to get it to work, so I could start the bike.
I recently bought a Concours ignition off a wreck for $30, just so I could dissect it. I don't think the manual, shows the inner workings of one.
I haven't drilled out the factory break off screws to remove the triple clamp yet, but have removed the door where the solenoid switch is. It has a finger that falls into slots on the barrel, where the key is. While it is engaged, the finger prevents rotation of the key tumbler. When the key is pressed in and KiPass is satisfied, the finger is lifted by the solenoid switch.
The finger is located in that small slot, above the solenoid.
The plastic capsule is where the wires are sealed in a silicon like substance, maybe a solid state board in there.
Under this door is the tumbler where the infamous spring, that gets replaced, is located.
I'll put more photos up after I get everything apart, then the more knowledgeable can explain the inner workings for us.
Offline tonedeaf
« Reply #8 on: January 15, 2012, 02:22:28 PM »
...at which point they put the old spring in the glove box KiPiss where is still doesn't work worth a damn.
« Reply #9 on: January 15, 2012, 02:25:56 PM »
Not implying anything but do you use the stove knob key for everything, or does it spend it's whole life in the ignition?
Hopefully you get this taken care of without any additional headache.
« Reply #10 on: January 15, 2012, 02:27:57 PM »
I wouldn't put it past them to do that..  :rotflmao:
Offline lolife
« Reply #11 on: January 15, 2012, 02:58:10 PM »
I've only removed my stove knob once just to do it.  I use the key in the back of the fob for my bags.
Offline texrider
« Reply #12 on: January 15, 2012, 05:24:01 PM »
I use the 'stove knob' key to open fuel and bag locks, and I occasionally give all key slots a shot of WD-40. Nary a problem so far, save one low FOB battery. (Knocks on wood)
2014 Valkyrie
« Reply #13 on: January 15, 2012, 05:49:59 PM »
WD-40 isn't the best thing to use since it actually attracts dirt and displaces grease.  I use a dab of dry graphite lube and it doesn't wash any of the good stuff away.
Offline rcannon409
« Reply #14 on: January 15, 2012, 05:57:34 PM »
Is it a good idea to remove the stovetop occasionally?
« Reply #15 on: January 15, 2012, 06:30:08 PM »
Bad juju...
Offline JerBear
« Reply #16 on: January 15, 2012, 06:34:20 PM »
I think Ma Kawi would be best served if they went to a regular key and spent the money they saved on a better way to keep the bags in place.  Kipass is a solution looking for a problem and by golly if there isn't a problem it will create one without a solution!
2008 C14 Non-ABS
« Reply #17 on: January 15, 2012, 07:49:25 PM »
I do not believe it makes any difference whether you remove the key or not. Some people have a belief that removing the key is somehow bad but I think that is entirely superstitious. Clearly Kawasaki meant for the key to be removed or they would not have put the letters "FSS" on the ring around the key in the position where it can be removed (Fuel, Saddlebags, Seat or Saddle). I remove the stove knob key from the ignition whenever I need to open anything on the bike and have since 7/07 and coming up on 80K miles without incident. Then again, I am the one who invented the KiPass Bypass too....  :D
There is a lot of 'hocus pocus' about KiPass but much like 'kill the virgin, grow the corn', it seems to work but there is no correlation IMO.
« Reply #18 on: January 15, 2012, 09:05:26 PM »
I was going to say the same thing.  WD-40 should not be used in locks and intricate mechanical works.  It tends to gum up things and attract dirt.  It is great for unfreezing simple mechanical, like rusted hinges.  It is also good for removing sticky stuff, followed by something like alcohol to get rid of the WD-40.
I have always been told that graphite is the only proper stuff to use in locks.
« Reply #19 on: January 15, 2012, 09:07:39 PM »
I think they should scrap kipass and replace it with a simple, intelligent (chipped) key, to help deter theft.  Then spend the saved money on an integrated, factory cruise control and HID lights.
