Author Topic: Rear accessory leads  (Read 10177 times)
Offline Bob Skinner
« on: May 18, 2011, 05:17:45 PM »
OK, I've tried a "search" and no info. Took out the toolkit and ecu. Still can't find them. Looked in the rubber pouch and no luck. Where did the factory hide the rear accessory leads?
Bob
Re: Rear accessory leads
« Reply #1 on: May 18, 2011, 05:40:31 PM »
You must pull the ECU out of the way (at the rear under the seat) . Then behind that (under the rack) in front of the tail light is a black boot. Inside that boot is the accessory wires. One male (common), one female (12volt+)
« Reply #2 on: November 25, 2011, 07:24:59 AM »
Offline PolterGeist
« Reply #3 on: December 21, 2015, 08:59:31 AM »
http://www.pbase.com/fredharmon/accleads
Great pics.. Hey quick question from a Newbie.. As I understand it (and if I understand it), there are two accessory leads one in the front and one in the rear... As I am new to Connie's, this is new to me, can anyone explain what these are typically used for? Sory if that is a stupid question, but as I said I fall back on to new to know.. :)
2014 Candy Cardinal Red Connie
« Reply #4 on: December 21, 2015, 09:32:29 AM »
They are for the bike's owner to add small electrical accessories. The Gen.2 C-14's are limited to 5 amps on the acc. circuit, so it will easily power things like GPS's, sound systems (without large, external speakers), charge cell phones and so forth. They will not power up most aux. lighting, heated clothing or any other such devices that use large amount of power.
By the way, if looking at lighting, heated clothing and some other things, they will be rated in watts rather than amps. No problem: divide the wattage by the system voltage (easiest to use 12 and close enough for our purposes) and come up with the amperage. Example: 100 Watt lights draw just over 8 amps (100 / 12 = 8 1/3) so they could not be powered by the aux. electrical circuit already on the bike, located in the front and rear as you mention.
Offline PolterGeist
« Reply #5 on: December 21, 2015, 09:39:33 AM »
Brian,
Perfect.. Thanks for all of the information...
« Reply #6 on: December 21, 2015, 11:48:57 AM »
Glad to help if I can.
Brian,
