Author Topic: SEAT ADJUSTMENT  (Read 3179 times)
Offline F-106
SEAT ADJUSTMENT
« on: January 07, 2012, 07:08:36 PM »
Been needing to get the seat adjusted for a while now. Went through the summer with the seat the way it was thinking it would do but no dice. I told Rocky to make it a few inches wider. He did , he added a full 2 for a full 18 inches across. He also flattened out the rear seat for the wife so she does not slide foward into me at stoplights. I will pick it up next monday.
IN THRUST WE TRUST
Offline papasmurf
Re: SEAT ADJUSTMENT
« Reply #1 on: January 08, 2012, 03:25:32 AM »
sounds like my seat i had done a few years back. it feels a lot more comfy with
seat being wider. i hope it works for you and yours. i will post pics of my bike and trailer when i
work out how to do it !
Offline throb
Re: SEAT ADJUSTMENT
« Reply #2 on: January 08, 2012, 04:30:12 AM »
  I did mine several weeks ago, replacing most of the stock foam with layers of differing density foam I bought from local upholstery shops.  It took a few trial and error fitments, but I think it's dialed in very well; at least a ton better than the stock seat foam.  My sit bones would start screaming at me after 90 minutes or so.  Built up the nose too so I don't slide forward into the tank anymore.   ;D
Offline throb
Re: SEAT ADJUSTMENT
« Reply #3 on: January 08, 2012, 04:32:16 AM »
...and the wife didn't even yell at me when she found out I was using our bread knife to trim the foam!   :thumbs:
Offline jworth
Re: SEAT ADJUSTMENT
« Reply #4 on: January 08, 2012, 02:26:52 PM »
I'm interested to see how you cover it.  Also, what did you use to adhere the different foams together?
Offline F-106
Re: SEAT ADJUSTMENT
« Reply #5 on: January 08, 2012, 05:29:28 PM »
The cover will be black with blue piping to match the passenger backrest. As far a the glue goes, Rocky use a industerial type glue applied under airpressure. It is good stuff. He has done 4 seats for me over the last 10 years and never a problem with the seat coming apart.
IN THRUST WE TRUST
Offline jworth
Re: SEAT ADJUSTMENT
« Reply #6 on: January 09, 2012, 08:17:12 AM »
Are we supposed to know who Rocky is?  Is this an upholstery buddy of yours?  I assume he is going to sew the new cover for you?  Is he going to use some kind of attachment to make the seat cover conform to the concave spot in the seat?
Offline F-106
Re: SEAT ADJUSTMENT
« Reply #7 on: January 09, 2012, 04:31:16 PM »
Yes, Rocky is a upholstery buddy of mine. He has been doing motorcycle seat for 40 years. Here is a link
http://www.rockybags.com/index.html
IN THRUST WE TRUST
