Author Topic: Vance & Hines CSOne Black Finally Installed  (Read 4651 times)
Offline shreveportSS
Re: Vance & Hines CSOne Black Finally Installed
« Reply #20 on: January 16, 2012, 07:55:04 PM »
Has anyone checked the air/fuel ratio after installing the CS One? I am wanting one, but I don't want to be running too lean. Especially in the 100*+ summer heat.
2011 Concours 14
2011 ZX1000GBF Ninja. Died Dec. 1st, 2012
2012 ZX1000HBF Ninja.
Offline Gearhead82
« Reply #21 on: January 17, 2012, 11:56:51 AM »
Running too lean won't be a concern.  Even with a full exhaust system, aftermarket air filter, flies removed, etc. the C14 still runs rich through almost the entire RPM range.
« Reply #22 on: January 20, 2012, 07:22:33 AM »
I run in economy mode quite a bit and just want to know if I need to buy a controller. I do notice the bike gets hotter on those 100+* days in economy mode. The main benifit of running rich is cylinder cooling. I guess I will call their tech line and see if they have a clue.
2011 Concours 14
