Author Topic: A&R Motorsports HID kit input  (Read 52435 times)
Offline overlord
Re: A&R Motorsports HID kit input
« Reply #20 on: January 10, 2012, 02:26:15 PM »
sounds like a pretty good deal... I'm in - 9 more to go
« Reply #21 on: January 10, 2012, 02:33:17 PM »
I'm going to sticky a new thread in the C14 Accessory area.  It will have more visibility there.
Group buy thread set up....  http://www.zggtr.org/index.php?topic=6291.0
« Reply #22 on: January 10, 2012, 02:41:25 PM »
Patrick, how long are you going to run this special?
Offline aandrmotorsport
« Reply #23 on: January 10, 2012, 02:51:14 PM »
There is no expiration as of right now, I will offer special forum pricing as long as I am allowed.
-Patrick
« Reply #24 on: January 10, 2012, 02:53:27 PM »
Thanks!
« Reply #25 on: January 10, 2012, 02:58:52 PM »
What bulb temp is everyone getting?
« Reply #26 on: January 10, 2012, 03:55:49 PM »
I just got the 6000k setup Sparky.  :)
« Reply #27 on: January 10, 2012, 04:39:20 PM »
That is up to them.  ;)
« Reply #28 on: January 10, 2012, 05:30:10 PM »
Maybe one of you guys can help but when I try to get into A&R's website I get this every time:
Forbidden
You don't have permission to access /directions/concourshidinstructions.html on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.16 (Unix) mod_ssl/2.2.16 OpenSSL/0.9.8e-fips-rhel5 mod_mono/2.6.3 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 mod_perl/2.0.4 Perl/v5.8.8 Server at www.aandrmotorsport.com Port 80
« Reply #29 on: January 10, 2012, 05:32:16 PM »
True.  But as a novice in HID lighting I would like to be enlightened on why so many bulb temps.  What does a higher temp signify?  Brightness?  Will the higher temps draw LEOs?  I'm interested in improving the lighting but I don't want to melt anything in the bike to get it.
In looking at your website, I don't want anything looking blue so I think the 4300k would work for me.  It has the most lumens as well.  Is bulb life related to color or lumens?
Offline RBX QB
« Reply #30 on: January 10, 2012, 05:57:37 PM »
To build on your query...
Question for those smarter than I... How much brighter is the 4300k(3100 lumen) compared to the 6000k(2900 lumen)? I assume that the cutoffs would be similar... but I'm just trying to gauge the brightness, as I HATE lights that appear to be blinding to oncoming drivers/riders.
2011 Concours 14 ABS
« Reply #31 on: January 11, 2012, 10:32:44 AM »
Even more questions: Is the color temp based on the ballast, the bulb, or the combo? You see the next question coming right?
wait for it now.....wait... ::)
What's involved to change from 4300k to 6000k and/or reverse?
« Reply #32 on: January 11, 2012, 10:41:59 AM »
The bulbs decide the temp (color).  They can be swapped very easily since everything in the A&R kit comes with weatherproof connections.
« Reply #33 on: January 13, 2012, 09:53:57 AM »
The bulb temps refer to the color of light that it puts out. Higher temps will likely draw LEOs. None of the temps should melt your bike, just know that the higher you go in temp, the less light it puts out. Bulb life on the higher temps is substantially shorter on the higher temp bulbs than it is on the 4300k and 6000k bulbs.
So sorry it took me so long to respond, I wish the forum sent me an email letting me know  you guys were replying.
-Patrick
« Reply #34 on: January 13, 2012, 10:27:35 AM »
-Patrick
You can set it up to email you in your settings Patrick.
Just don't let Jim tell you to change your email address...  :-X
« Reply #35 on: January 13, 2012, 10:29:56 AM »
« Reply #37 on: January 13, 2012, 10:39:10 AM »
I figured out what I was doing wrong. I am not used to this forum software.
-Patrick
« Reply #38 on: January 13, 2012, 12:27:11 PM »
And sometimes neither are we..
« Reply #39 on: January 14, 2012, 08:13:11 PM »
Thanks Jeremy!
