Have a NIB Audiovox setup with extras. Have had this unit since about March of this year and have never installed. Now a issue has showed up that I need to fix and will sacrifice the CC.
As mentioned it is as I received with parts still wrapped. In addition a vaccum canister is included along with 2 styles of pad brackets. One will fit right side while the other is left side and points up from handlebar. Notice in the pic the left pad bracket has a pad mounted. This is a Rostra pad I purchased for a past Connie to replace a water damaged pad. The Rostra pad was never used BTW and goes with the package.
With this setup nothing else need be purchased to operate CC. Am pricing all you see in pic and described at 160.00 shipped to lower 48.
Thanks,
Roger
