Author Topic: Anyone remove peg feelers?  (Read 12764 times)
Re: Anyone remove peg feelers?
« Reply #20 on: May 19, 2011, 09:35:42 AM »
Jeremy, what kind of tires are you running to put sooo....much faith in?
I was running PR2's front and rear, but I am using a PR2 on the front and a Shinko Raven on the rear currently.  I actually like the Raven on the rear and will probably run this combo again.  I have never felt that I have exceeded my tires capabilities.
Offline COGnosticat0r
« Reply #21 on: May 19, 2011, 09:57:23 AM »
Have you gone through a Raven yet, just wondering what mileage you got out of the rear.  I am estimating only 3,400 miles out of the one I have on there now.  >:(
Jerry Holland
COG 4478
2013 C14
« Reply #22 on: May 19, 2011, 10:03:32 AM »
I didn't write down my exact mileage when I put it on, but I am at approximately 3700 miles.  I currently have about 2 mm down the center and 3-4 on the sides from all my commuting and lack of twisty road running.  I am shooting for another 1000 miles out of them, as long as I can spend the majority of the time leaning instead of slabbing it.
I will say that the wear on the Raven is much more uniform that with my PR2.  The left and right sides are nearly identical.  The PR2 showed a huge difference between the right and left side.
Offline Assassin 11B3P
  • The C14 is vastly overrated.
« Reply #23 on: May 19, 2011, 03:20:42 PM »
by removing the feeler, you can improve mpg's by at least 15%.
Please use this forum to demonstrate your own ignorance, unfamiliarity with empirical data, ability to repeat discredited memes, and lack of respect for scientific knowledge. Also, be sure to create straw men and argue against things I have neither said nor even implied. Any irrelevancies you can mention will also be appreciated.
