Author Topic: How Low Can You Go? (Lowering your Connie) by Elvin Rivera  (Read 13139 times)
Offline elvin315
  • Global Moderator
Chubby Checker Limbo Rock
I am 5'8" with a 30" inseam and can flat foot the bike when stopped. It helps that my considerable weight helps bring the bike closer to the ground. My Russell seat changed that when it raised me an inch. I'm not uncomfortable with the new seat height so I haven't needed any of this but I've collected the info from friends who have lowered their Concours.
Some owners raise the forks through the triple clamps but I wouldn't recommend doing it by more than an inch, if even that much. Too much, without lowering the rear to match, will change the front end's rake & trail, make her twitchy and prone to tank slappers. Backing out the fork preload adjusters (or decreasing the fork air pressure in the pre-94 models) will also lower the front a bit but limits the range to which you can set your sag. Raise the fork tubes before doing this but do it in small increments to minimize the affects to your geometry. Any ride height changes should be made at both ends of the bike. Remember that lowering the bike will reduce the ground clearance, increasing the chances of dragging hard parts while leaning.
The rear can be lowered some by decreasing the air pressure in the OEM shock. Gary Murphy is a Progressive Suspension dealer and sells their 420 shock absorber. It's available with a shorter length piston rod that lowers the rear. There are other shocks with this feature too. Lowering the rear will cancel the side-affects of raising the fork tubes.
http://www.murphskits.com/rear.htm
http://www.hyperprousa.com/home.php
http://davequinnmotorcycles.com
There is a method of lowering the rear that uses the OEM shock. It's not available in kit form but any machinist should be able to make the few parts that aren't available from a hardware supply. See it at:
http://cog-online.org/clubportal/clubstatic.cfm?clubID=1328&pubmenuoptID=30521
http://www.mcmaster.com
Norm (SawDust) Soucy has created an ingenious way to lower the rear. Remove three bolts, three sets of bearings, and reassemble using his Lowering Rocker. People are raving about it. Search: Lowering Rocker and you'll get the whole story.
http://good-times.webshots.com/album/553501216YvJxVH
http://www.pbase.com/elvin315/image/65657845
Norm Soucy: sanleon@galvestonbay.net
One way to lower your feet approximately 3/4 inch (math wasn't my strong point in HS so I could be off) is to convert your wheels to 17 inchers. Read the related articles in the FAQ for the multiple benefits to this as well as techniques.
http://www.zggtr.org/index.php?topic=1293.0
http://www.zggtr.org/index.php?topic=1292.0
This solution will bring your feet closer to the pavement and maintain the bike's ground clearance. I mention it last since it can't be reversed easily. Your seat can be re-contoured or even cut down at any auto or marine upholstery shop, or DIY if you prefer. Trimming the sides of the seat foam will make it easier to extend your legs down to the ground. Shaving the seat foam on top will lower you. Inserting firmer foam or a gel pad will keep you from touching the seat pan as a result of the thinner padding. Custom seats can also be purchased to accomplish the same thing and improve on the original's comfort but beware. If you don't specify a lower seat height, the new seat can raise you higher than before. Also, some aftermarket seats are wider at the "nose" and make it harder to touch down. A narrower contour there would help a shorter legged rider. Speak with the manufacturers before ordering.
http://billmayersaddles.com
http://www.richscustomseats.com/photodisplay.asp?id=jap14
http://www.day-long.com
http://www.corbin.com/saddles.shtml
http://www.sargentcycle.com
http://www.itrocks.com/motorcycles/gel_seat.htm
http://www.fjr1300.info/mods/richs.html
http://www.zrxoa.org/webpages/techinfo/seats/seatmod/seatmod1.html
http://faq.f650.com/FAQs/AftermarketSeatsFAQ.htm
http://www.amspecialtiesusa.com/gelpad.htm
http://allmanproducts.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=CSH
http://www.motorcycleseatcovers.com/
WARNING: Lower the bike too much and she'll stand more upright when on the sidestand. The odds of a tipover increase the more you lower the bike. The cure is cutting a section from the sidestand and rewelding it. Lowering also increases the effort needed to place her on the centerstand. Again, the remedy is to shorten the legs. Any of these mods, alone or in combination, should lower the Connie to suit you but beware: Too low and halfway through that fast sweeper or emergency maneuver and a hard part like the exhaust will touch down and jack a tire off the road. Think any mods over and chose carefully.
« Last Edit: August 07, 2011, 08:14:36 PM by elvin315 »
