Author Topic: Need help: GSG Frame Slider bolt or nut stripped  (Read 7221 times)
Offline roadie
Re: Need help: GSG Frame Slider bolt or nut stripped
« Reply #20 on: December 02, 2011, 04:58:32 PM »
Stupidity.  Being rushed.
I didn't RTFM.
I started locking the nut down without the one inch spacer on the left side, nor did I have the left peg hanging on the left side before I started hunkering down on the nut.  By the time I realized I had screwed up, the damn nut was jammed all the wayup passed the threads on the end of the bolt...thats when the damage occured... I managed to get the nut back off then, put in the spacer, peg, and started screwing the nut back on...at which point i hit a stripped point on the nut, and the heffer just started spinning.
In a nut shell, slow the fock down, RTFM, and don't try and do a farkle 20 minutes before you need to leave for work.
« Last Edit: December 03, 2011, 12:14:05 AM by Roadie »
Will
« Reply #21 on: December 03, 2011, 06:48:01 AM »
Glad to hear that you got it worked out Will.
« Reply #22 on: December 03, 2011, 08:38:57 AM »
I am confused, do you have the ProjektD or the GSG Moto sliders?
Offline roadie
« Reply #23 on: December 03, 2011, 09:37:47 AM »
I have gsg. I scratched out projektd. Mind was elsewhere when I wrote the first time.
Will
Offline roadie
« Reply #24 on: December 05, 2011, 07:18:48 AM »
So i contacted GSG in Germany, and they are sending me the new bolt.  Come to find out the big nut on the opposite end is just mounted with locktite.  I asked them to send me the entire new assembly.  Total cost 38 Euro to my door.  I've got the new engine mount nut on order from Ron Ayers.
Will
