Author Topic: "black" sludge floating in master Brake cylinder  (Read 11926 times)
Offline roadie
« on: December 01, 2011, 05:07:41 PM »
Am I imagining things?  It was night when I got home, but I have noticed my pads are down to approx 1.5mm, I hear what sounds almost like a dull hiss when I grab the front brakes, and when I got home, it "appeared" like I had some black "sludge" floating on top of brake fluid in master brake cylinder. Lil lost...I mean, I know my pads need changing and plan to do next week when Connie goes down for mx, but the floaters? The sound?  Is that the sound the pads make when they are about toast?  I thought for sure I'd get more than 15,000 miles out of the shoes, but I guess I use them alot.  Any input...appreciated...thx
« Last Edit: December 04, 2011, 05:27:08 AM by Roadie »
Will
Re: "black" sludge floating in master Break cylinder
« Reply #1 on: December 01, 2011, 05:19:47 PM »
If you are looking into the master cylinder reservoir from the outside, through the walls, then I would not worry about it. It is probably the plastic damper (anti- slosh plate) that floats on top of the brake fluid. The plate is really a piece of white foam but the edges turn black from the fines in the brake fluid. If you are not used to seeing that thing float in the M.C. it would probably look odd to you. By the way, once the edge does turn dark it is hard or impossible to clean it so you will get used to it.
No one has found any sludge type material in a C-14 brake system, at least not that I have heard of. The brake fluid is totally isolated so it is unlikely to become contaminated (you can turn the master cylinder upside down and it will not leak). Brake fluid does turn darker with time and eventually gets nearly black but there should not be anything thick in the fluid.
Am I imagining things?  It was night when I got home, but I have noticed my pads are down to approx 1.5mm, I hear what sounds almost like a dull hiss when I grab the front breaks, and when I got home, it "appeared" like I had some black "sludge" floating on top of brake fluid in master break cylinder. Lil lost...I mean, I know my pads need changing and plan to do next week when Connie goes down for mx, but the floaters? The sound?  Is that the sound the pads make when they are about toast?  I thought for sure I'd get more than 15,000 miles out of the shoes, but I guess I use them alot.  Any input...appreciated...thx
Offline roadie
« Reply #2 on: December 01, 2011, 05:23:16 PM »
Thx Brian, puts me at ease a bit...what about the noise? Is there a tell tale sign when pads are going bad?
Will
« Reply #3 on: December 01, 2011, 05:32:49 PM »
I don't know- I never burned all the way through a set of pads on a motorcycle. That said, all the motorcycle brakes I have experienced do make a 'hissing' sound with good pads.
It is easy to check the pads with a flashlight and without taking anything apart. You will have to maneuver your head and the light around a bit but you will be able to see the edges of the pads and there should be a gap between the steel backing plate of the pad and the rotor (the gap IS the pad material). Stock brakes have a groove in them that serves as a wear indicator- if you can see any of that groove, the pads are OK. You <might> need a small mirror to see all the pads but it is still quite easy.
I find motorcycle pads look dangerously worn when they are only 1/2 used up. They are thin to begin with, and appear even thinner when still inside the caliper. I have seen a lot of "worn out" pads that are less than 1/2 used up when compared with brand new pads. In fact, brand new pads look a little worn out to most of us. At least they are cheap, right?  ::)
Offline roadie
« Reply #4 on: December 01, 2011, 05:40:39 PM »
Just sounds like a louder hiss lately...maybe becauase I'm feeling the maintenance bug and thinking it needs...I'll check again, but thinking I saw about 1.5 mm of pad left last weekend when I checked.  Thanks Brian. Always super helpful insight.
Will
« Reply #5 on: December 01, 2011, 07:43:12 PM »
You can't stop any more?
Offline roadie
« Reply #6 on: December 01, 2011, 07:47:50 PM »
:) still stops just making a new noise I've never heard before.
Will
« Reply #7 on: December 01, 2011, 10:48:07 PM »
You're just listening better.
« Reply #8 on: December 02, 2011, 03:36:53 AM »
 :thumbs:
« Reply #9 on: December 04, 2011, 04:48:42 AM »
BTW, it's brakes, not breaks.
Goof. ;D
Offline roadie
« Reply #10 on: December 04, 2011, 05:23:44 AM »
Duh :). I'll fix. Of all people it had to be the boy from Arkansas that catches the typo. Geez.
Will
« Reply #11 on: December 04, 2011, 07:23:01 AM »
« Reply #12 on: December 04, 2011, 08:51:23 AM »
I'm from KC MO.
But I love tearing up the twistys in Arkansas. 8)
Offline Z71
« Reply #13 on: December 05, 2011, 08:44:22 PM »
I'm from KC MO.
By the way, it is "twisties",  not "twistys"    ;D
Re: "black" sludge floating in master Brake cylinder
« Reply #14 on: December 06, 2011, 05:17:30 PM »
Damnit! :o
I can't remember the last time I messed that one up! :P
 8)
« Reply #15 on: December 06, 2011, 05:19:04 PM »
Seams theirs a speling insurection in progress....
« Reply #16 on: December 06, 2011, 05:19:52 PM »
As long as it does not get inciteful....
« Reply #17 on: December 06, 2011, 05:25:30 PM »
Quite!
« Reply #18 on: December 07, 2011, 05:01:09 AM »
Damnit! :o
 8)
Hey Jimmy, it's dammit not damnit.     ;D
That'll learn ya!
« Reply #19 on: December 07, 2011, 07:32:12 AM »
This thread delivers
