Author Topic: Raising your air hand wings coverage a bit for free...  (Read 4276 times)
« on: November 26, 2011, 05:34:46 PM »
Simple solution that I just came across, if you're running risers and wedges and want to raise the height of wind blockage of your air hand wing's a bit just put the small spacer on the top and the longer spacer on the bottom (opposite of how the instructions tell ya), it will still clear the dash plastic and shield no problem. It totally changes the angle of the mounting bracket which raises em up, it also put's them more in line with the angle of your windscreen for a more blended look. It works great, I just took mine out for a rip, can't believe I didn't think of this before, and free is a good price to try it...
« Last Edit: November 26, 2011, 06:34:34 PM by ZG »
Offline So Cal Joe
Re: Raising your air hand wings coverage a bit for free...
« Reply #1 on: November 26, 2011, 05:57:45 PM »
Great information, and an easy solution, I just made bigger wing
Offline BudCallaghan
« Reply #2 on: November 27, 2011, 01:49:59 AM »
Can you please explain what this means Joe?
Sorry to ignore the subject but this is a question that begs an answer.  I assume others would also like to know but are too polite to ask.
« Reply #3 on: November 27, 2011, 06:29:44 AM »
Please - NO RELIGION HERE.
« Reply #4 on: November 27, 2011, 06:31:59 AM »
I like one of our members response to Joe's tag line.
"born ok the first time"
« Reply #5 on: November 27, 2011, 06:34:42 AM »
Lather's comment is right on the mark.  Please explore this via PM or email, Bud.
« Reply #6 on: November 27, 2011, 07:45:51 AM »
Going back to the OP...this is for a 10 on, correct?
« Reply #7 on: November 27, 2011, 07:54:54 AM »
ZG has an '09 Jim.
« Reply #8 on: November 27, 2011, 08:36:57 AM »
I should have known that....Thanks.
« Reply #9 on: November 27, 2011, 10:07:32 AM »
Yep, I have an 09.
Will swapping the spacers not work on a 10+? Or do they not have spacers?
« Reply #10 on: November 27, 2011, 10:11:20 AM »
The spacers on my Motax deflectors are both the same size ZG.
« Reply #11 on: November 27, 2011, 10:19:10 AM »
Good point C, the ProjektD ones have a short and a long spacer.
You could get some shorter spacers for the top from your local hardware store, the concept should be the same for the Motax ones and will change the angle of the mounting point to raise the wing protection zone.
« Reply #12 on: November 27, 2011, 10:24:23 AM »
You could get some shorter spacers for the top from your local hardware store, the concept should be the same and will change the angle of the mounting point to raise the wing protection zone C.
IF I was to need it, I would have to go with longer spacers Z. Any shorter and the mounting bracket from the Motax deflectors would be hitting the bike's plastic.
Mine are perfect the way they are anyways. I don't have any risers or wedges nor do I need/want them.
« Reply #13 on: November 27, 2011, 10:27:17 AM »
Yep, this is true, shorter on top or longer on bottom will have the same effect to change the angle.
