Author Topic: how to remove plastic rivets?  (Read 8768 times)
Offline h2smokin
« on: May 17, 2011, 03:59:52 PM »
I'm trying to remove flat panel under the running lights to replace those bulbs. How do the little button rivets come apart? Don't feel like having to replace those if they break, thanks
Re: how to remove plastic rivets?
« Reply #1 on: May 17, 2011, 04:07:27 PM »
They are tricky the first time.
Push the center pin in about 1/8" until it 'clicks' then remove the entire rivet- it will come out easily. To reuse the rivets, remove the center pin and install it into the rivet with about 1/8" of pin sticking out beyond the rivet head. Insert the rivet and then push the center pin in flush to the rivet head.
Offline h2smokin
« Reply #2 on: May 17, 2011, 05:41:50 PM »
thanks worked like a charm. Just wanted to install the little 6k led bulbs I picked up. Gonna get some spare rivets though as they are cheap looking. Thanks again
