Author Topic: What will I gain with Power Commander?  (Read 6465 times)
Offline jkramer
« on: November 21, 2011, 04:54:46 PM »
I have a 2008 concours,2brothers ex.,k&n air filter, and flies removed. What will I gain in HP and fuel milege by adding a power commander. Also what is the difference between the PC and a juice box.Thanks
« Last Edit: November 22, 2011, 04:15:49 AM by VirginiaJim »
Re: whar will I gain
« Reply #1 on: November 21, 2011, 05:05:44 PM »
You running stock header w/cats?
Offline jkramer
« Reply #2 on: November 21, 2011, 05:12:58 PM »
stock header w/ 2 bro. slip on
« Reply #3 on: November 21, 2011, 05:23:45 PM »
Can't comment on the juice box, never used one. With the exhaust still restricted your main gains have already been realized.  An FI modifier will give you a better A/F which will increase mileage somewhat. A PC V with Autoune will give you as good as you can get without dyno tuning. An ECU reflash is another option.
Re: What will I gain with Power Commander?
« Reply #4 on: November 22, 2011, 04:17:04 AM »
Gentle reminder for all....it really helps to have a descriptive subject line.
Offline Rawman
« Reply #5 on: November 23, 2011, 01:55:01 PM »
Better fuel economy, more power.....
2009 Non-ABS
Offline rcannon409
« Reply #6 on: November 23, 2011, 04:28:13 PM »
On my 08, I gained a lot of lower rpm smoothness.  That range as you leave a stoplight at normal speed.   Removing the files gave the bike more power, but the pcv made the power feel much nicer.  Fuel mileage is up as well, by abotu 5-8% IF I lay off the throttle.
Based on what I've said, if it somehow turned out the pcv was taking power away (its not, but IF), I would still run it. The improved low rpm response if great.
Offline curly
« Reply #7 on: November 24, 2011, 06:34:29 AM »
For me it wasn't the gain in hp but the peace of mind knowing the fuel ratio is correct.
'09 in Black.
Offline jkramer
« Reply #8 on: November 24, 2011, 04:43:00 PM »
Thanks, Im still new @ this so im learning. I do know that removing the flies was a great improvement. Im getting 40-42 mpg at present riding 2 up and Ill be ordering the pc soon. Again thanks
