Author Topic: Oil filter with Spoofak  (Read 2823 times)
Offline Squishman
« on: November 14, 2011, 02:33:16 PM »
I went to get a Fram TG7317 oil filter. That's the one I used last year, so I figured I'd stick with that, but they were out of that one.
So I got the upgraded one, XG7317. The box says it is designed for synthetic oil and I use dino.
Think it's fine and just use it anyway?
The TG is on Dan's list, but the XG is not.
Todd
Eagan, MN
Photos of my 1999 Conk: http://s751.photobucket.com/home/Squishman/index
Fav farkles: custom-cut Corbin Seat, Sonic 1.2's, Sisf's righteous carb work, Yamaha ATV bars, Spoofak, Rifle Shield, Stick Coils.
Offline Sparkie
Re: Oil filter with Spoofak
« Reply #1 on: November 14, 2011, 04:05:11 PM »
I don't see why it won't work. I think the XG stands for extended guard supposedly. It probably has a fancier metal cover with the grip material that aids in turning it. I think you'll be fine. Mark
Offline Squishman
« Reply #2 on: November 14, 2011, 04:10:55 PM »
It says "specifically engineered two-ply synthetic media reinforced with a metal screen delivers up to 10,000 miles of engine protection".
Todd
Eagan, MN
Offline throb
« Reply #3 on: November 14, 2011, 05:07:33 PM »
 :popcorn:  Waiting patiently for the Fram nay-sayers (myself included) to chime in...
Offline Squishman
« Reply #4 on: November 14, 2011, 05:13:26 PM »
I hope not. That would be lame. I just wanted to know if it was as good of a filter for dino.
Thx Sparkie, btw.
Todd
Eagan, MN
« Reply #5 on: November 14, 2011, 05:21:24 PM »
Thx Sparkie, btw.
It will be fine; only difference is that filter has higher filtration standards to enable it to stay on the engine longer just as the synthetic oil is designed to stay in the engine longer. Fram "HAD" some issues with some of their filters LONG ago; if anyone thinks that they are a substandard filter still today for that reason their heads have been buried in the ground far too long.
BTW I don't know if they still do a filter with the teflon additive now that was bad news too....
Offline Outback_Jon
« Reply #6 on: November 14, 2011, 06:11:34 PM »
Heh.  I started a reply about that, but killed it when I didn't see anything on Fram's website about any teflon additives.
I'd stay away from their "High Mileage" filters, though, as their site states the following:
Gel additives help balance oil PH and helps neutralize acids and helps slows down viscosity increase
