Author Topic: Cleaning question  (Read 5069 times)
Offline AZBiker
    • My photos
Re: Cleaning question
« Reply #20 on: November 18, 2011, 02:44:13 AM »
To clarify, somewhat off-topic:
DOT 5.0 is sillycone based.  It is fine on paint.  Stock fluid for many H-Ds.  Expensive compared to DOT 3&4.  Incompatible with 3, 4 & 5.1.  It does not absorb water either.  The water will eventually make its way into the bottom of the system if allowed to accumulate long enough.  Switching to DOT 5 is fine, just flush the system REAL good.  If I ever switched I would go ahead and rebuild my master cylinder and calipers, drain all the lines, and take everything apart to ensure no trace of the old stuff remained.  YMMV.  Allegedly, 5 doesn't have the same "feel" but I ran a stainless brakeline on my XLH and my brakes were plenty firm.  I'm sure TCro's brakes are fine too.
For those that want to stick with a DOT 3/4 compatible formula, there is DOT 5.1.  Higher BP than 3 & 4.  Relatively hard to find and also expensive.  Like 3 & 4, 5.1 absorbs water.  Not a big deal if you maintain your system properly.
You want a higher BP for your fluid?  Break out the wallet.
rubber side down,
Derek
93 Cali black & red
