Well I finally got a few pics of the rr hub coupler I had to replace last week.
Wow is all I can say about its demise. I was totally surprised by its damage, but it was almost completly hidden when it was mounted on the wheel.
It is such a tight fit, the edges on the splines, that weren't gone hid the middle, grab area of the shafts connection to the hub.
My suggestion to all, if you have a rainy day, or your changing a rear tire, take the time to un-clip the set ring, pull your hub coupler and check it out. It's one of the easiest things to miss as far as a wear item on our beloved Connies.
Everyone be safe out there.
Greg
